On this page
Show all
Why Do I Fail to Create a Hive Table?
Updated on 2024-10-25 GMT+08:00
Question
Why do I fail to create a hive table?
Answer
Creating a Hive table fails, when source table or sub query has more number of partitions. The implementation of the query requires a lot of tasks, then the number of files will be output a lot, resulting OOM in Driver.
It can be solved by using distribute by on suitable cardinality(distinct values) column in the statement of Hive table creation.
distribute by clause limits number of hive table partitions. It considers cardinality of given column or spark.sql.shuffle.partitions which ever is minimal. For example, if spark.sql.shuffle.partitions is 200, but cardinality of column is 100, out files is 200, but the other 100 files are empty. So using very low cardinality column like 1 will cause data skew and will effect later query distribution.
So we suggest using the column with cardinality greater than spark.sql.shuffle.partitions. It can be greater than 2 to 3 times.
Example:
create table hivetable1 as select * from sourcetable1 distribute by col_age;
