DELETE RECORDS from CARBON TABLE
Function
This command is used to delete records from a CarbonData table.
Syntax
DELETE FROM CARBON_TABLE [WHERE expression];
Parameter Description
Table 1 DELETE RECORDS parameters
CARBON TABLE
Name of the CarbonData table in which the DELETE operation is performed
Precautions
  • If a segment is deleted, all secondary indexes associated with the segment are deleted as well.
  • If the carbon.input.segments property has been set for the queried table, the DELETE operation fails. To solve this problem, run the following statement before the query:
    Syntax:
    SET carbon.input.segments. <database_name>.<table_name>=*;
Examples
  • Example 1:
    delete from columncarbonTable1 d where d.column1 = 'country';
  • Example 2:
    delete from dest where column1 IN ('country1', 'country2');
  • Example 3:
    delete from columncarbonTable1 where column1 IN (select column11 from sourceTable2);
  • Example 4:
    delete from columncarbonTable1 where column1 IN (select column11 from sourceTable2 where column1 = 'xxx');
  • Example 5:
    delete from columncarbonTable1 where column2 >= 4;
System Response
Success or failure will be recorded in the driver log and on the client.
