CHANGE DATA TYPE
Function
This command is used to convert INT to BIGINT or increase decimal precision.
Syntax
ALTER TABLE [db_name.]table_name CHANGE col_name col_name changed_column_type;
Parameter Description
Table 1 CHANGE DATA TYPE parameters
db_name
Database name. If this parameter is not specified, the current database is selected.
table_name
Table name.
col_name
Name of a column in a table. A column name consists of letters, digits, and underscores (_).
changed_column_type
Target data type.
Precautions
  • The decimal precision conversion is available only when no data is lost. The decimal precision is represented in the (precision, scale) format.
    • Unavailable: Decimal precision cannot be changed from (10,2) to (10,5) because only the scale increases, but the total number of digits remains unchanged.
    • Available: Decimal precision can be changed from (10,2) to (12,3). The total number of digits increases by 2 but the scale increases only by 1, which does not cause any data loss.
  • The maximum precision allowed is (38,38).
Example
  • Convert the data type of column a1 from INT to BIGINT.
    ALTER TABLE test_db.carbon CHANGE a1 a1 BIGINT;
  • Change the precision of column a1 from 10 to 18.
    ALTER TABLE test_db.carbon CHANGE a1 a1 DECIMAL(18,2);
Response
You can run the DESCRIBE command to check the changed data type of the modified column.
