CarbonData Data Types
In CarbonData, data is stored in entities called tables. CarbonData tables are similar to RDBMS tables which organize data in rows and columns. CarbonData tables store structured data, and have fixed columns and data types.
Supported Data Types
CarbonData tables support the following data types:
  • Int
  • String
  • BigInt
  • Smallint
  • Char
  • Varchar
  • Boolean
  • Decimal
  • Double
  • TimeStamp
  • Date
  • Array
  • Struct
  • Map
The following table describes supported data types and their respective values ranges.
Table 1 CarbonData data types
Data Type
Value Range
Int
4-byte signed integer ranging from -2,147,483,648 to 2,147,483,647.
int data in a non-dictionary column is internally stored as the BigInt type.
String
100,000 characters
If the CHAR or VARCHAR data type is used in CREATE TABLE, the two data types are automatically converted to the String data type.
If a column contains more than 32,000 characters, add the column to the LONG_STRING_COLUMNS attribute of the tblproperties table during table creation.
BigInt
64-bit value ranging from -9,223,372,036,854,775,808 to 9,223,372,036,854,775,807
SmallInt
–32,768 to 32,767
Char
A to Z and a to z
Varchar
A to Z, a to z, and 0 to 9
Boolean
true or false
Decimal
The default value is (10,0) and maximum value is (38,38).
When query with filters, append BD to the number to achieve accurate results. For example, select * from carbon_table where num = 1234567890123456.22BD.
Double
64-bit value ranging from 4.9E-324 to 1.7976931348623157E308
TimeStamp
The default format is yyyy-MM-dd HH:mm:ss.
Date
The DATE data type is used to store calendar dates. The default format is yyyy-MM-DD.
Array<data_type>
N/A
Currently, only two layers of complex types can be nested.
Struct<col_name: data_type COMMENT col_comment, ...>
Map<primitive_type, data_type>
Main Specifications of CarbonData
Table 2 Main specifications
Entity
Tested Value
Test Environment
Number of tables
10000
3 nodes. 4 vCPUs and 20 GB memory for each executor. Driver memory: 5 GB, 3 executors.
Total columns: 107
String: 75
Int: 13
BigInt: 7
Timestamp: 6
Double: 6
Number of table columns
2000
Maximum size of a raw CSV file
200GB
17 cluster nodes. 150 GB memory and 25 vCPUs for each executor. Driver memory: 10 GB, 17 executors.
Number of CSV files in each folder
100 folders. Each folder has 10 files. The size of each file is 50 MB.
Number of load folders
10000
Table Specifications
Table 3 Table specifications
Entity
Tested Value
Number of secondary index tables
10
Number of composite columns in a secondary index table
5
Length of column name in a secondary index table (unit: character)
120
Length of a secondary index table name (unit: character)
120
Cumulative length of all secondary index table names + column names in an index table* (unit: character)
3800**
  • * Characters of column names in an index table refer to the upper limit allowed by Hive or the upper limit of available resources.
  • ** Secondary index tables are registered using Hive and stored in HiveSERDEPROPERTIES in JSON format. The value of SERDEPROPERTIES supported by Hive can contain a maximum of 4,000 characters and cannot be changed.
