Open Source sqoop-shell Tool Usage Guide
Updated on 2024-10-25 GMT+08:00
Overview
Sqoop-shell is a shell tool of Loader. All its functions are implemented by executing the sqoop2-shell script.
The sqoop-shell tool provides the following functions:
  • Creating and updating connectors
  • Creating and updating jobs
  • Deleting connectors and jobs
  • Starting jobs in the synchronous or asynchronous mode.
  • Stopping jobs
  • Viewing job status
  • Viewing historical execution records of jobs
  • Cloning connectors and jobs
  • Creating and updating conversion steps
  • Specifying line and field separators
The sqoop-shell tool supports the following modes:
  • Interaction mode
    Users execute the sqoop2-shell script without parameters to go to the particular interaction window of Loader. After the contents of the script are input, the tool returns the relevant information to the interaction window.
  • Batch mode
    The sqoop2-shell script has a file name as a parameter and multiple commands are stored in lines in the file. The sqoop-shell tool runs all commands in the file in sequence by executing the script. Alternatively, users can execute the sqoop2-shell script, to the end of which a command is attached with the -c parameter as the bridge. In this case, the sqoop-shell tool runs one command each time.
The sqoop-shell implements functions of Loader by running the commands in Table 1.
Table 1 Command list
Command
exit
Exits the interaction mode.
This command is supported only in the interaction mode.
history
Views the executed commands.
help
Views the tool help information.
set
Sets server attributes.
show
Displays service attributes and all the metadata information of Loader.
create
Creates connectors and jobs.
update
Updates connectors and jobs.
delete
Deletes connectors and jobs.
clone
Clones connectors and jobs.
start
Starts jobs.
stop
Stops jobs.
status
Views job status.
Commands
  • The sqoop2-shell tool provides two methods to obtain login authentication information. The first method is to obtain login authentication information from the configuration file. For details about the configuration items, see Importing Data to HDFS Using sqoop-shell and Importing Data to HDFS Using sqoop-shell. The second one is to obtain the authentication information by using parameters. Two modes are available in the second method: password mode and Kerberos authentication mode.
  • Command for accessing the interaction mode
    Execute the sqoop2-shell script without parameters to go to the sqoop tool window and run the commands one by one.
    Run the following command to obtain the authentication information by reading the configuration file:
    ./sqoop2-shell
    Run the following command to authenticate login using the password mode:
    ./sqoop2-shell -uk false -u username -p encryptedPassword
    Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
    Run the following command to authenticate login using the Kerberos mode:
    ./sqoop2-shell -uk true -k user.keytab -s userPrincipal
    The following information is displayed:
    Welcome to sqoop client
    Use the username and password authentication mode
    Authentication success.
    Sqoop Shell: Type 'help' or '\h' for help.
    sqoop:000>
  • Command for entering the batch mode
    Two methods are available for accessing the batch mode.
    • Execute the sqoop2-shell script, in which a file name is used as a parameter and multiple commands are stored in lines in this file. The sqoop-shell tool runs all commands in the file in sequence. The script must be stored in the home directory of the current user, for example, /root/batchCommand.sh.
      Run the following command to authenticate login by reading configuration files:
      ./sqoop2-shell /root/batchCommand.sh
      ./sqoop2-shell -uk false -u username -p encryptedPassword /root/batchCommand.sh
      ./sqoop2-shell -uk true -k user.keytab -s userPrincipal /root/batchCommand.sh
      batchCommand.sh is the user-defined name of the text file.
    • Execute the sqoop2-shell script, to the end of which a command is attached with the -c parameter as the bridge. The sqoop-shell tool will execute the command.
      ./sqoop2-shell -c expression
      ./sqoop2-shell -uk false -u username -p encryptedPassword -c expression
      ./sqoop2-shell -uk true -k user.keytab -s userPrincipal -c expression
      expression is the attached statement, whose format is the same as that in the text file in the first method.
  • Exit command
    This command is used for exiting the interaction mode and supported only in the interaction mode.
    Example:
    sqoop:000> exit
    10-5-211-9:/opt/hadoopclient/Loader/loader-tools-1.99.3/sqoop-shell#
  • History command
    This command is used for viewing the executed commands and supported only in the interaction mode.
    Example:
    sqoop:000> history
       0  show connector
       1  create connection -c 4
       2  show connections;
       3  show connection;
       4  show connection -a;
       5  show connections;
       6  show connection;
       7  show connection -x 53;
       8  show connection -x 52;
       9  show connection -x 2
      10  show connection -x 53;
      11  show connection
      12  show connection -x 53
      13  create job -x 53 -t import
      14  show connector
      15  create connection -c 5
      16  show connection -x 54
      17  exit
      18  show connector
      19  create connection -c 5
      20  exit
      21  show connector
      22  create connection -c 6
      23  create job -x 20 -t import
      24  start job -j 85 -s
      25  \x
      26  exit
      27  history
    sqoop:000>
  • Help command
    This command is used for viewing the tool help information.
    Example:
    sqoop:000> help
    For information about Sqoop, visit: http://sqoop.apache.org/docs/1.99.3/index.html
    Available commands:
      exit    (\x  ) Exit the shell
      history (\H  ) Display, manage and recall edit-line history
      help    (\h  ) Display this help message
      set     (\st ) Set server or option Info
      show    (\sh ) Show server, connector, framework, connection, job, submission or option Info
      create  (\cr ) Create connection or job Info
      delete  (\d  ) Delete connection or job Info
      update  (\up ) Update connection or job Info
      clone   (\cl ) Clone connection or job Info
      start   (\sta) Start job
      stop    (\stp) Stop job
      status  (\stu) Status job
    For help on a specific command type: help command
    sqoop:000>
  • Set command
    The set command is used for setting attributes of clients and servers and supports the following attributes:
    • server indicates setting the connection attributes for servers.
      When attribute -u is set, attributes -h, -p, and -w can be ignored.
    • option indicates setting the client attributes.
      option can be set by key values. For example, set option --name verbose --value true.
      Attribute Type
      Subattribute
      server
      -h,--host
      Service IP address.
      -p,--port
      Service Port
      -w,--webapp
      Tomcat application name.
      -u,--url
      Sqoop service URL.
      option
      verbose
      Redundancy mode, which indicates that more information is printed.
      poll-timeout
      Sets the polling timeout duration.
    Example:
    set option --name verbose --value false
    set server --host 10.0.0.1 --port 21351 --webapp loader
  • show command
    This command is used for displaying information, such as variable information and storage metadata information.
    Attribute Type
    Subattribute
    server
    -a,--all
    Displays all server attributes.
    -p,--port
    Displays the service port.
    -w,--webapp
    Displays the Tomcat application name.
    -h,--host
    Displays the service IP address.
    option
    -name
    Displays the attributes of the specified name.
    connector
    -a,--all
    Displays information about all connection types.
    -c,--cid
    Displays information about the connection type of a specified ID.
    framework
    None.
    Displays metadata information about frameworks.
    connection
    -a,--all
    Displays all connection attributes.
    -x,--xid
    Displays the attributes of a specified connection.
    -n,--name
    Displays the connection attributes of a specified name.
    job
    -a,--all
    Displays information about all jobs.
    -j,--jid
    Displays job information about a specified ID.
    -n,--name
    Displays job information about a specified name.
    submission
    -j,--jid
    Displays the submission record of a specified job.
    -d,--detail
    Displays details.
    Example:
    show server -all
    show option --name verbose
    show connector -all
    show framework
    show connection -all
    show connection -n sftp-example
    show job -all
    show job -j 1
    show submission --jid 1
    show submission --jid 1 -d
  • Create command
    This command is used for creating connectors and jobs.
    Attribute Type
    Subattribute
    connection
    -c,--cid
    Specifies the ID of a connector type.
    -cn,--cname
    Specifies the name of a specified connector type.
    job
    -x,--xid
    Specifies the connector ID.
    -xn,--xname
    Specifies the connector name.
    -t,--type
    Specifies the job type.
    Possible values:
    • import
    • export
    • In the interaction mode, enter the attribute values one by one as prompted.
      Example for creating connectors:
      create connection -c 1
      create connection -cn example
      Example for creating jobs:
      create job -x 1 -t import
      create job -xn job_example -t export
    • In the batch mode, run the following command to view the specific attribute and then set a value for the attribute:
      create job -t import -x 1 --help
      You can run the above command in either of the following ways:
      Save the command to a text file and attach this file to the end of the sqoop-shell script, and run the following command:
      ./sqoop2-shell batchCommand.sh
      Attach a command with the -c parameter to the end of the sqoop-shell script and run the following command:
      For details about command execution, refer to previous description in this section. The following shows two complete commands:
      create connection -c 4 --connector-connection-sftpPassword xxxxx --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root--name testConnection
      create job -t import -x 1 --connector-file-inputPath /opt/tempfile --connector-file-fileFilter * --framework-output-outputDirectory /user/loader/1 --framework-output-storageType HDFS --framework-throttling-extractorSize 120 --framework-output-fileType TEXT_FILE --connector-file-splitType FILE -queue default -priority low -name newJob
    • In the batch mode, you can attach a statement using the -c parameter as the bridge.
      ./sqoop2-shell -c "create connection -c 4 --connector-connection-sftpPassword xxxxx --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root--name testConnection"
  • update command
    This command is used for updating connectors and jobs.
    Attribute Type
    Subattribute
    connection
    -x,--xid
    When the connectors are updated, the password must be set.
    job
    -j,--jid
    Specifies the job ID.
    • Interaction mode
      Example for updating connectors:
      update connection --xid 1
      Example for updating jobs:
      update job --jid 1
    • Batch mode
      update connection -x 6 --connector-connection-sftpServerPort 21 - --name sfp_130--connector-connection-sftpPassword xxxx
      Example 1:
      update job -jid 1 -name sftp2hdfs --connector-file-fileFilter *.txt
      Example 2:
      ./sqoop2-shell -uk true -k /opt/loader/user.keytab -s luser /opt/loader/testupdate.txt
      ./sqoop2-shell -uk true -k /opt/loader/user.keytab -s luser -c "update job --jid 24 --name oracle-hive --connector-table-sql 'SELECT * FROM range_example WHERE replace(datadt,\'-\',\'\')='20240801' and \${CONDITIONS}'"
      When updating a job, you can write the update commands in a file, for example, /opt/loader/testupdate.txt (the file name can be customized), or specify the commands using --connector-table-sql, in which the sql command must be enclosed in single quotation marks ('). For details, see example 2. Involved commands include connector-table-sql, connector-table-columns, connector-table-partitionColumn, connector-table-conditions, connector-table-queryCondition.
  • delete command
    This command is used for deleting connectors and jobs.
    Attribute Type
    Subattribute
    connection
    -x,--xid
    -n,--name
    job
    -j,--jid
    -n,--name
    Specifies the job name.
    Example:
    delete connection -x 1
    delete connection --name abc
    delete job -j 1
    delete job -n qwerty
  • clone command
    This command is used for cloning connectors and jobs.
    Attribute Type
    Subattribute
    connection
    -x,--xid
    The password and connector name must be entered when the connectors are cloned.
    job
    -j,--jid
    Example:
    clone job -j 1
  • start command
    This command is used for starting jobs.
    Attribute Type
    Subattribute
    job
    -j,--jid
    -n,--name
    -s,--synchronous
    Whether to start jobs in the synchronous mode or not.
    Example for starting jobs in the asynchronous mode:
    start job -j 1
    start job -n abc
    Example for starting jobs in the synchronous mode:
    start job -j 1 -s
    start job --name abc --synchronous
  • stop command
    This command is used for stopping jobs.
    Attribute Type
    Subattribute
    job
    -j,--jid
    -n,--name
    Example:
    stop job -j 1
    stop job -n abc
  • Status command
    This command is used for viewing job status.
    Attribute Type
    Subattribute
    job
    -j,--jid
    When -s parameter is attached to the command, the result only contains the enumerated value of job status.
    Example:
    status job -j 1
    status job -j 1 -s
Extended Attributes of Create Command
For the scenario in which HDFS exchanges data with the SFTP server or RDB, MRS extends the create command attributes on the basis of the open source sqoop-shell tool, so as to specify line and field separators and conversion steps when jobs are created.
Table 2 Extended Attributes of Create Command
Property
fields-terminated-by
Default field separator.
lines-terminated-by
Default line separator.
input-fields-terminated-by
Inputs the step field separator. If the step field separator is not specified, the value equals to fields-terminated-by by default.
input-lines-terminated-by
Inputs the step line separator. If the step line separator is not specified, the value equals to lines-terminated-by by default.
output-fields-terminated-by
Outputs the step field separator. If the step field separator is not specified, the value equals to fields-terminated-by by default.
output-lines-terminated-by
Outputs the step line separator. If the step line separator is not specified, the value equals to lines-terminated-by by default.
trans
Specifies the conversion steps. The value is the directory where the conversion step file is located. When the relative directory of file is specified, the file is by default stored in the directory where the sqoop2-shell script is located. When the attribute is set, the other extended attributes can be ignored.
Interconnecting Sqoop1 with MRS
  1. Download the open source Sqoop from http://www.apache.org/dyn/closer.lua/sqoo:p/1.4.7.
  2. Save the downloaded sqoop-1.4.7.bin__hadoop-2.6.0.tar.gz package to the /opt/sqoop directory on the Master node in the MRS cluster and decompress the package.
    tar zxvf sqoop-1.4.7.bin__hadoop-2.6.0.tar.gz
  3. Go to the directory where the package is decompressed and modify the configuration.
    cd /opt/sqoop/sqoop-1.4.7.bin__hadoop-2.6.0/conf
    cp sqoop-env-template.sh sqoop-env.sh
    vi sqoop-env.sh
    Add the following configurations:
    export HADOOP_COMMON_HOME=/opt/client/HDFS/hadoop
    export HADOOP_MAPRED_HOME=/opt/client/HDFS/hadoop
    export HIVE_HOME=/opt/Bigdata/MRS_1.9.X/install/FusionInsight-Hive-3.1.0/hive (Enter the actual path.)
    export HIVE_CONF_DIR=/opt/client/Hive/config
    export HCAT_HOME=/opt/client/Hive/HCatalog
  1. Add the system variable SQOOP_HOME to PATH.
    vi /etc/profile
    Add the following information:
    export SQOOP_HOME=/opt/sqoop/sqoop-1.4.7.bin__hadoop-2.6.0
    export PATH=$PATH:$SQOOP_HOME/bin
  2. Run the following command to copy the jline-2.12.jar file to the lib file.
    cp /opt/share/jline-2.12/jline-2.12.jar /opt/sqoop/sqoop-1.4.7.bin__hadoop-2.6.0/lib
  3. Run the following command to add the following configuration to the file.
    vim $JAVA_HOME/jre/lib/security/java.policy
    permission javax.management.MBeanTrustPermission "register";
  4. Run the following command to interconnect sqoop1 with MRS.
    source /etc/profile
