On this page
schedule-tool Usage Example
Updated on 2024-10-25 GMT+08:00
After a job is created using the Loader WebUI or Loader-tool, use schedule-tool to execute the job.
The Loader client has been installed and configured. For details, see Running a Loader Job by Using Commands.
  1. In the directory /opt/houjt/test03 on the SFTP server, create multiple files with table1 as the prefix, .txt as the suffix, and yyyyMMdd as the date format in the middle of the file name.
    Figure 1 Example
  2. Create a Loader job of importing data from the SFTP server to HDFS. For details, see Using Loader to Import Data from an SFTP Server to HDFS or OBS.
  3. Log in to the node where the client is located as the user who installs the client.
  4. Run the following command to go to the conf directory of schedule-tool. For example, if the Loader client installation directory is /opt/client/Loader/, run the following command:
    cd /opt/client/Loader/loader-tools-1.99.3/schedule-tool/conf
  5. Run the following command to edit the schedule.properties file and configure the login mode:
    vi schedule.properties
    schedule-tool supports two login modes. Only one mode can be selected. For parameter details, see schedule-tool Usage Guide. There can be security risks if a configuration file contains the authentication password. You are advised to delete the configuration file or use other secure methods to keep the password.
    • When the password mode is used for login, the configuration information example is as follows:
      [server.url = 10.10.26.187:21351,127.0.0.2:21351]
      [authentication.type = kerberos]
      [use.keytab = false]
      [authentication.user = admin]
      # Passwords stored in plaintext pose security risks. Store them in ciphertext in configuration files or environment variables.
      [authentication.password= xxx]
    • When the keytab file mode is used for login, the configuration information example is as follows:
      [use.keytab = true]
      [client.principal = bar]
      [client.keytab = /opt/hadoopclient/Loader/loader-tools-1.99.3/loader-tool/hadoop-config/user.keytab]
      [krb5.conf.file = /opt/hadoopclient/Loader/loader-tools-1.99.3/loader-tool/hadoop-config/krb5.conf]
  6. Run the following command to edit the job.properties file and configure job information:
    vi job.properties
    #job name
    job.jobName = sftp2hdfs-schedule-tool
    #Whether to update the loader configuration parameters(File filter)£?This parameter is used to match the import file name.Values are true or false.
    #false means update.the file name which is get by schedule tool will be updated to Loader configuration parameters (File filter).
    #false means no update.the file name which is get by schedule tool will be updated to Loader configuration parameters (import path).
    file.filter = false
    #File name = prefix + date + suffix
    #Need to import the file name prefix
    file.fileName.prefix=table1
    #Need to import the file name suffixes
    file.fileName.posfix=.txt
    #Date Days.Value is an integer.
    #According to the date and number of days to get the date of the import file.
    date.day = 1
    #Date Format.Import file name contains the date format.Format Type£ºyyyyMMdd,yyyyMMdd HHmmss,yyyy-MM-dd,yyyy-MM-dd HH:mm:ss
    file.date.format = yyyyMMdd
    #Date Format.Scheduling script execution. Enter the date format.
    parameter.date.format = yyyyMMdd
    #Whether the import file is a compressed format.Values ??are true or false.
    #true indicates that the file is a compressed format£?Execution scheduling tool will extract the files.false indicates that the file is an uncompressed.Execution scheduling tool does not unpack.
    file.format.iscompressed = false
    #Hadoop storage type.Values are HDFS or HBase.
    storage.type = HDFS
    According to the data provided by 1, the filtering rules are set as follows when the table120160221.txt file is used as an example:
    • File name prefix:
    • File name suffix:
    • Date format included in the file name:
    • Entered date parameter for invoking the script:
    • Number of delayed days.
      date.day = 1
      For example, if the input date parameter of the script is 20160220, the result is 20160221 by using the addition.
      If the ./run.sh 20160220 /user/loader/schedule_01 command is executed, the preceding filtering rules will be combined into a string: "table1"+"20160221"+.txt = table120160221.txt.
  7. Select a filtering rule according to the value of file.filter.
    • If a file is to be exactly matched, go to 8.
    • If a series of files are to be fuzzily matched, go to 9.
  8. Change the value of file.filter in the job.properties file to false.
    Run the following commands to run the job. The task is completed.
    20160220 indicates the input date, and /user/loader/schedule_01 indicates the output path.
    The string table120160221.txt obtained by combining the preceding filtering rules will be used as the file name and appended to the input path of the job. Therefore, the job will only process the uniquely matched file table120160221.txt.
  9. In the job.properties file, change the value of file.filter to true, and set the value of file.fileName.prefix to *.
    The string *20160221.txt obtained by combining the preceding filtering rules will be used as the fuzzy match mode of the file filter. In the input path of the job, all files matching *20160221.txt will be processed by the job.
