File Output
Overview
The File Output operator uses delimiters to concatenate existing fields and exports new fields to a file.
Input and Output
- Input: fields to be exported
 - Output: files
Parameter Description
        Parameter  |
        Description  |
        Type  |
        Mandatory  |
        Default Value  |
        Output delimiter  |
        Set a delimiter.  |
        string  |
        Yes  |
        None  |
        Line breaker  |
        Line delimiter, which can be any string specified by users based on the actual situation. Any character string is supported. The OS line delimiter is used by default.  |
        string  |
        No  |
        \n  |
        Output fields  |
        Information about output fields:
        map  |
        No  |
        None  |
Data Processing Rule
The field is exported to a file.
Example
Use the CSV File Input operator to generate two fields A and B.
The following figure shows the source file.
aaa,product bbb,Bigdata
Configure the File Output operator, set Output delimiter to a comma (,), and export A and B to a file, as shown in the following figure.
The following figure shows the result.
