Concat Fields
Overview
The Concat Fields operator concatenates existing fields by using delimiters to generate new fields.
Input and Output
  • Input: fields to be concatenated
  • Output: new fields
Parameter Description
Table 1 Operator parameter description
Type
Mandatory
Default Value
Output field name
Name of a field generated after concatenation.
string
Yes
None
Delimiter
Concatenation character. The value can be blank.
string
No
Empty string
Fields to be merged
Names of fields to be concatenated.
field name must be set to the names of fields generated in the previous conversion step. Multiple field names can be added.
map
Yes
None
Data Processing Rule
  • Use delimiters to concatenate the fields specified by Fields to be merged in order and assign the output to Output field name.
  • If the value of a field is null, the value is changed to an empty string and then concatenated with other field values.
Example
Use the CSV File Input operator to generate fields A, B, and C.
The following figure shows the source file.
Configure the Concat Fields operator, set Delimiter to blank space, and generate field D.
After concatenation, fields A, B, C, and D are generated, as shown in the following figure.
