Long Date Conversion
Overview
The Long Date Conversion operator performs long integer and date conversion.
Input and Output
  • Input: fields to be converted
  • Output: new fields
Parameter Description
Table 1 Operator parameter description
Type
Mandatory
Default Value
convert type
Types of long integer and date conversion:
  • long to date: converts long integers to date.
  • long to time: converts long integers to time.
  • long to timestamp: converts long integers to timestamp.
  • date to long: converts date to long integers.
  • time to long: converts time to long integers.
  • timestamp to long: converts timestamp to long integers.
enum
Yes
long to date
input field name
Name of input fields to be converted. Set this parameter to the names of fields generated in the previous conversion step.
string
Yes
None
output field name
Names of output fields.
string
Yes
None
field unit
Unit of a long integer field. According to convert type, the value is an input field or generated field. The options are second and millisecond.
enum
Yes
second
output field type
Output field type. The options are BIGINT, DATE, TIME, and TIMESTAMP.
enum
Yes
BIGINT
date format
Time field format, for example, yyyyMMdd HH:mm:ss.
string
No
None
Data Processing Rule
  • If the original data includes null values, no conversion is performed.
  • If the number of input field columns is greater than the number of field columns actually included in the original data, all data becomes dirty data.
  • If a type conversion error occurs, the current data is saved as dirty data.
Example
Use the CSV File Input operator to generate fields A and B.
The following figure shows the source file.
Configure the Long Date Conversion operator to generate four new fields C, D, E, and F. Their types are DATE, TIME, TIMESTAMP, and BIGINT, respectively.
The following figure shows the output of the conversion.
