CSV File Input
Overview
The CSV File Input operator imports all files that can be opened by using a text editor.
Input and Output
  • Input: test files
  • Output: fields
Parameter Description
Table 1 Operator parameter description
Type
Mandatory
Default Value
Delimiter
Delimiter in a CSV file for separating data lines.
string
Yes
Line Delimiter
Line delimiter, which can be any string specified by users based on the actual situation. The OS line delimiter is used by default.
string
No
\n
Filename as field
User-defined field whose value is the name of the file that stores the current data.
string
No
None
Absolute path
Indicates whether the file name used as the value of Filename as field contains an absolute path. Selecting the option button indicates that the file name contains an absolute path; deselecting the option button indicates that the file name does not contain a path.
boolean
No
Deselect
Validate input field
Checks whether the input field matches the value type. If the value is NO, no check is performed. If the value is YES, whether the input field matches the value type is checked. If the input fields do not match the value type, the line is skipped.
enum
Yes
YES
Input fields
Information about input fields:
  • position: Position of the field after data lines in the source file are separated by delimiters. The position sequence starts from 1.
  • field name: Field name.
  • type: Field type.
  • date format: If the field type is DATE, TIME, or TIMESTAMP, you must specify a time format. If the field type is set to other values, the time format is invalid. An example time format is yyyyMMdd HH:mm:ss.
  • length: Field value length. If the actual field value is excessively long, the value is cut based on the configured length. When type is set to CHAR, spaces are added to the field value for supplement if the actual field value length is less than the configured length. When type is set to VARCHAR, no space is added to the field value for supplement if the actual field value length is less than the configured length.
map
Yes
None
Data Processing Rule
  • Each data line is separated into multiple fields by using delimiters and the fields are used by the subsequent conversion operator.
  • If the field value does not match the actual type, the data in the line will become dirty data.
  • If the number of input field columns is equal to the number of field columns actually included in the original data, the data in the line will become dirty data.
Example
The following figure shows the source file.
Configure the CSV File Input operator, set Delimiter to a comma (,), and generate fields A and B.
Fields A and B are generated, as shown in the following figure.
