Viewing Historical Information About a Loader Job
Query the execution status and execution duration of a Loader job during routine maintenance. You can perform the following operations on the job:
- Dirty Data: Query data that fails to be processed or data that is filtered out during job execution, and check which source data does not meet transformation or cleaning rules.
- Logs: Query log information about job execution in MapReduce.
You have obtained the username and password for logging in to the Loader WebUI.
- Access the Loader web UI.
- Log in to FusionInsight Manager. For details, see Accessing FusionInsight Manager.
- Choose Cluster > Services > Loader.
- Click LoaderServer(Node name, Active). The Loader web UI is displayed. Figure 1 Loader web UI
- Query historical records of a Loader job.
- Locate the row that contains the job to be viewed.
- Click More and select View History to view the job execution history. Figure 2 Viewing historical records
Table 1 Parameters Name
Rows/Files Read
Indicates the number of rows (files) read from the input source.
Rows/Files Written
Number of rows (files) written to the output source.
Rows/Files Skipped
- Indicates the number of bad rows (files) recorded during transformation. The input format is incorrect, so transformation cannot be performed.
- Number of rows that are skipped after filtering conditions are configured during conversion.
