How Do I Develop a Third-Party Flume Plug-in
- Install the Flume client, for example, in the /opt/flumeclient directory.
- Compress the self-developed code into a JAR package.
- Create a directory for the plug-in.
- Go to Flume client installation directory/fusionInsight-flume-*/plugins.d and run the following command to create a directory. The directory name can be changed based on the site requirements.
cd /opt/flumeclient/fusioninsight-flume-1.9.0/plugins.d
mkdir thirdPlugin
cd thirdPlugin
mkdir lib libext native
The command output is displayed as follows:
- Place the third-party JAR package in Flume client installation directory/fusionInsight-flume-*/plugins.d/thirdPlugin/lib. If the JAR package depends on other JAR packages, place the dependent JAR packages in Flume client installation directory/fusionInsight-flume-*/plugins.d/thirdPlugin/libext. Stores local library files in Flume client installation directory/fusionInsight-flume-*/plugins.d/thirdPlugin/native.
- Configure the Flume client installation directory/fusionInsight-flume-*/conf/properties.properties file.
For details about how to set parameters in the properties.properties file, see the parameter list in the properties.properties file in the corresponding typical scenario Configuring a Non-Encrypted Flume Data Collection Task and Configuring an Encrypted Flume Data Collection Task.
