On this page
Show all
How Do I View Flume Logs
Updated on 2024-10-25 GMT+08:00
Flume logs are stored in /var/log/Bigdata/flume/flume/flumeServer.log. Most data transmission exceptions and data transmission failures are recorded in logs. You can run the following command:
tailf /var/log/Bigdata/flume/flume/flumeServer.log
  • Problem: After the configuration file is uploaded, an exception occurs. After the configuration file is uploaded again, the scenario requirements are still not met, but no exception is recorded in the log.
    Solution: Restart the Flume process, run the kill -9 Process code to kill the process code, and view the logs.
  • Issue: "java.lang.IllegalArgumentException: Keytab is not a readable file: /opt/test/conf/user.keytab" is displayed when HDFS is connected.
    Solution: Grant the read and write permissions to the Flume running user.
  • Problem: The following error is reported when the Flume client is connected to Kafka:
    Caused by: java.io.IOException: /opt/FlumeClient/fusioninsight-flume-1.9.0/cof//jaas.conf (No such file or directory)
    Solution: Add the jaas.conf configuration file and save it to the conf directory of the Flume client.
    vi jaas.conf
    KafkaClient {
    com.sun.security.auth.module.Krb5LoginModule required
    useKeyTab=true
    keyTab="/opt/test/conf/user.keytab"
    principal="flume_hdfs@<System domain name>"
    useTicketCache=false
    storeKey=true
    debug=true;
    Values of keyTab and principal vary depending on the actual situation.
  • Problem: The following error is reported when the Flume client is connected to HBase:
    vi jaas.conf
    Client {
    useKeyTab=true
    principal="flume_hbase@<System domain name>"
    storeKey=true
    debug=true;
  • Question: After the configuration file is submitted, the Flume Agent occupies resources. How do I restore the Flume Agent to the state when the configuration file is not uploaded?
    Solution: Submit an empty properties.properties file.
