Customizing Row Separators in Hive Tables
In most cases, a carriage return character is used as the row delimiter in Hive tables stored in text files, that is, the carriage return character is used as the terminator of a row during queries. However, some data files are delimited by special characters, and not a carriage return character.
MRS Hive allows you to use different characters or character combinations to delimit rows of Hive text data. When creating a table, set inputformat to SpecifiedDelimiterInputFormat, and set the following parameter before search each time. Then the table data is queried by the specified delimiter:
set hive.textinput.record.delimiter='';
The Hue component of the current version does not support the configuration of multiple separators when files are imported to a Hive table.
- Log in to the node where the Hive client is installed as the Hive client installation user.
- Run the following commands to switch to the client installation directory, configure environment variables, and authenticate users:
Switch to the client installation directory:
cd client installation directory
Load environment variables:
source bigdata_env
For authenticated users, if Kerberos authentication is not enabled for the cluster, skip this operation:
kinit Hive service user
- Run the following command to log in to the Hive client:
beeline
- Specify inputFormat and outputFormat when creating a table.
CREATE [TEMPORARY] [EXTERNAL] TABLE [IF NOT EXISTS] [db_name.]table_name [(col_name data_type [COMMENT col_comment], ...)] [ROW FORMAT row_format] STORED AS inputformat 'org.apache.hadoop.hive.contrib.fileformat.SpecifiedDelimiterInputFormat' outputformat 'org.apache.hadoop.hive.ql.io.HiveIgnoreKeyTextOutputFormat';
- Specify the delimiter before search.
set hive.textinput.record.delimiter='!@!';
Hive will use !@! as the row delimiter.
