Updated on 2026-06-27 GMT+08:00
Creating a Hive User and Binding the User to a Role
This section describes how to create a Hive user and bind the user to a role on Manager as an MRS cluster administrator. The Hive role can be granted the permissions of the Hive administrator and the permissions to operate Hive table data.
Creating a database with Hive requires users to join in the hive group, without granting a role. Users have all permissions on the databases or tables created by themselves in Hive or HDFS. They can create tables, select, delete, insert, or update data, and grant permissions to other users to allow them to access the tables and corresponding HDFS directories and files. The created databases or tables are saved in the /user/hive/warehouse directory of the HDFS by default.
Notes and Constraints
  • Hive roles can be created only if Kerberos authentication is enabled for the cluster (in security mode). If Kerberos authentication is disabled for the cluster (in normal mode), Hive roles cannot be created.
  • If Ranger is used for permission control, you need to configure related permission management policies. For details, see Adding a Ranger Access Permission Policy for Hive.
The MRS cluster administrator has understood service requirements.
Creating a Hive Role
Some default roles are preset in MRS. If these preset roles do not meet your business requirements, you can create custom roles. If the preset roles meet your requirements, skip this part.
  1. Log in to FusionInsight Manager. For details, see Accessing FusionInsight Manager.
  2. Choose System > Permission > Role.
  3. Click Create Role, and set Role Name and Description.
  4. Set Configure Resource Permission.
    • Grant the read and execution permissions for the HDFS directory.
      • Click Name of the desired cluster and select HDFS for Service Name. On the displayed page, click File System, choose hdfs://hacluster/ > user, locate the row where hive is located, and select Read and Execute in the Permission column.
      • Click Name of the desired cluster and select HDFS for Service Name. On the displayed page, click File System, choose hdfs://hacluster/ > user > hive, locate the row where warehouse is located, and select Read and Execute in the Permission column.
      • Click Name of the desired cluster and select HDFS for Service Name. On the displayed page, click File System, choose hdfs://hacluster/ > tmp, locate the row where hive-scratch is located, and select Read and Execute in the Permission column.
    • Hive Admin Privilege: Hive administrator permission.
    • Hive Read Write Privileges: Hive data table management permissions that allow users to configure and manage data in created tables.
    For details, see Table 1.
    • Hive role can be granted administrator permissions and permissions to access databases, tables, and views.
    • Hive administrator permissions do not include the permission to manage HDFS.
    • If there are too many tables in the database or too many files in tables, the permission granting may last for a while. For example, if a table contains 10,000 files, the permission granting lasts about 2 minutes.
    Table 1 Setting a role
    Task
    Role Authorization
    Setting the Hive administrator permission
    In the Configure Resource Permission table, choose Name of the desired cluster > Hive and select Hive Admin Privilege.
    After assigning the Hive administrator role to a user, perform the following operations during each maintenance session:
    1. Log in to the node where the Hive client is installed as the client installation user.
    2. Run the following command to configure environment variables. /opt/hiveclient indicates the Hive client installation directory.
      source /opt/hiveclient/bigdata_env
    3. Run the following command to authenticate the user:
      kinit Hive service user
    4. Run the following command to log in to the Hive client:
      beeline
    5. Run the following command to update the administrator permissions of the Hive user:
      set role admin;
    Setting the permission to query a table of another user in the default database
    1. In the Configure Resource Permission table, choose Name of the desired cluster > Hive > Hive Read Write Privileges.
    2. Click the name of the specified database in the database list. Tables in the database are displayed.
    3. In the Rights column of the specified table, choose Select.
    Setting the permission to insert a table of another user in the default database
    3. In the Permission column of the specified table, select INSERT.
    Setting the permission to import data to a table of another user in the default database
    3. In the Permission column of the specified indexes, select DELETE and INSERT.
    Setting the permission to submit HQL commands to Yarn for execution
    For some services, the HQL commands need to be converted into MapReduce tasks and submitted to Yarn for execution. In this case, you need to set the Yarn permissions. Such HQL statements may include insert, count, distinct, group by, order by, sort by, or join.
    1. In the Permission table, choose Name of the desired cluster > Yarn > Scheduling Queue > root.
    2. In the Permission column of the default queue, select Submit.
  5. Click OK. The system returns to the Role page.
    After a role is created, users bound to the role will have the corresponding permissions.
  2. Choose System > Permission > User.
  3. Above the user list, click Create and set the following parameters:
    • Username: Enter a user name, for example, hiveuser.
    • User Type: Select Human-Machine.
    • Password and Confirm Password: Enter a password.
    • User Group: Click Add, select a user group, for example, hive, and click OK.
    • Primary Group: Select a primary group based on service requirements, for example, hive.
    • Role: Click Add to bind a role to the user, for example, System_administrator.
      If the preset roles do not meet the requirements, create a role by referring to Creating a Hive Role and bind the role to the user.
  4. Click OK.
    After a human-machine user is created, you need to change the initial password as prompted after logging in to FusionInsight Manager.
  5. Log in to the Hive client as the created user. Then you can create, modify, and delete Hive tables. For details, see Using Hive for Data Analysis.
Helpful Links
