On this page
Yarn Log Overview
Log Description
The default paths for saving Yarn logs are as follows:
  • ResourceManager: /var/log/Bigdata/yarn/rm (run logs) and /var/log/Bigdata/audit/yarn/rm (audit logs)
  • NodeManager: /var/log/Bigdata/yarn/nm (run logs) and /var/log/Bigdata/audit/yarn/nm (audit logs)
Log archive rule: The automatic compression and archive function is enabled for Yarn logs. By default, when the size of a log file exceeds 50 MB, the log file is automatically compressed. The naming rule of the compressed log file is as follows: <Original log file name>-<yyyy-mm-dd_hh-mm-ss>.[ID].log.zip. A maximum of 100 latest compressed files are retained. The number of compressed files can be configured on Manager.
Log archive rule:
Table 1 Yarn log list
Log Type
Log File Name
Run log
hadoop-<SSH_USER>-<process_name>-<hostname>.log
Yarn component log file that records most of the logs generated when the Yarn component is running
hadoop-<SSH_USER>-<process_name>-<hostname>.out
Log file that records Yarn running environment information
<process_name>-<SSH_USER>-<DATE>-<PID>-gc.log
Garbage collection log file
yarn-haCheck.log
ResourceManager active/standby status detection log file
yarn-service-check.log
Log file that records the health check details of the Yarn service
yarn-start-stop.log
Log file that records the startup and stop of the Yarn service
yarn-prestart.log
Log file that records cluster operations before the Yarn service startup
yarn-postinstall.log
Work log file after installation and before startup of the Yarn service
hadoop-commission.log
Yarn service entry log file
yarn-cleanup.log
Log file that records the cleanup operation during uninstallation of the Yarn service
yarn-refreshqueue.log
Yarn queue refresh log file
upgradeDetail.log
Upgrade log file
stderr/stdin/syslog
Container log file of the applications running on the Yarn service
yarn-application-check.log
Check log file of applications running on the Yarn service
yarn-appsummary.log
Running result log file of applications running on the Yarn service
yarn-switch-resourcemanager.log
Run log file that records the Yarn active/standby switchover
ranger-yarn-plugin-enable.log
Log file that records the enabling of Ranger authentication for Yarn
yarn-nodemanager-period-check.log
Periodic check log of Yarn NodeManager
yarn-resourcemanager-period-check.log
Periodic check log of Yarn ResourceManager
hadoop.log
Hadoop client logs
env.log
Environment information log file before the instance is started or stopped.
Audit logs
yarn-audit-<process_name>.log
ranger-plugin-audit.log
Yarn operation audit log file
SecurityAuth.audit
Yarn security audit log file
Log Level
Table 2 describes the log levels supported by Yarn, including OFF, FATAL, ERROR, WARN, INFO, and DEBUG, from high priority to low. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Table 2 Log levels
Level
FATAL
Logs of this level record critical error information about the current event processing.
ERROR
Logs of this level record error information about the current event processing.
WARN
Logs of this level record exception information about the current event processing.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record the system as well as system debugging information.
To modify log levels, perform the following operations:
  1. Go to the All Configurations page of the Yarn service by referring to Modifying Cluster Service Configuration Parameters.
  2. On the menu bar on the left, select the log menu of the target role.
  3. Select a desired log level.
  4. Click Save Configuration. In the dialog box that is displayed, click OK to make the setting take effect.
    The configurations take effect immediately without the need to restart the service.
Log Format
The following table lists the Yarn log formats.
Table 3 Log formats
Log Type
Format
Example
Run log
<yyyy-MM-dd HH:mm:ss,SSS>|<Log Level>|<Thread that generates the log>|<Message in the log>|<Location of the log event>
2021-09-26 14:18:59,109 | INFO | main | Client environment:java.compiler=<NA> | org.apache.zookeeper.Environment.logEnv(Environment.java:100)
Audit log
2021-09-26 14:24:43,605 | INFO | main-EventThread | USER=omm OPERATION=refreshAdminAcls TARGET=AdminService RESULT=SUCCESS | org.apache.hadoop.yarn.server.resourcemanager.RMAuditLogger$LogLevel$6.printLog(RMAuditLogger.java:91)
