Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using YARN/ Enterprise-Class Enhancements of Yarn/ Configure the ApplicationMaster to Automatically Adjust the Allocated Memory
During the process of starting the configuration, when the ApplicationMaster creates a container, the allocated memory is automatically adjusted according to the total number of tasks, which makes resource utilization more flexible and improves the fault tolerance of the client application.
Configuration Description
Navigation path for setting parameters:
On Manager, choose Cluster > Name of the desired cluster > Service > Yarn > Configuration. On the displayed page, select All Configurations and enter mapreduce.job.am.memory.policy.
Configuration description
If the default value of the parameter is left empty. In this case, the automatic adjustment policy is not enabled. The memory of ApplicationMaster is still affected by the value of yarn.app.mapreduce.am.resource.mb.
The value of mapreduce.job.am.memory.policy consists of five items, and they are separated by colons (:) and commas (,) in the following format: baseTaskCount:taskStep:memoryStep,minMemory:maxMemory. The format is strictly checked when the value is entered.
Table 1 Parameter description
Setting Requirement
baseTaskCount
Indicates the total number of tasks. The configuration of ApplicationMaster is valid only when the total number of tasks (on the sum of the Map and Reduce ends) is greater than or equal to the value of this parameter.
The value cannot be empty and must be greater than 0.
taskStep
Indicates the incremental step length of tasks. This parameter and memoryStep determine the memory adjustment amount.
memoryStep
Indicates the incremental memory step. The memory capacity is increased based on the value of yarn.app.mapreduce.am.resource.mb.
The value cannot be empty and must be greater than 0. The unit is MB.
minMemory
Indicates the lower limit of the memory that can be automatically adjusted. If the memory after the automatic adjustment is less than or equal to the value of this parameter, the value of yarn.app.mapreduce.am.resource.mb is used.
The value cannot be empty. It must be greater than 0 and cannot be greater than the value of maxMemory.
Unit: MB
maxMemory
Indicates the upper limit of memory that can ve automatically adjusted. If the adjusted memory exceeds the upper limit, use this value as the final value.
The value cannot be empty. It must be greater than 0 and cannot be less than the value of minMemory.
Unit: MB
Example Value
Configuration:
  • yarn.app.mapreduce.am.resource.mb=1536
  • mapreduce.job.am.memory.policy=100:10:50,1200:2000
  • Total number of tasks of an application =120
The calculation process is as follows:
Memory after adjustment = 1536 + [(120 – 100)/10] x 50 = 1636. In this example, memory after adjustment 1636 is greater than the value of minMemory 1200, and less than the value of maxMemory 2000. Therefore, the ApplicationMaster memory is set to 1636 MB.
If the value of memStep is changed to 250, the calculation formula is as follows: Memory after adjustment = 1536 + [(120 – 100) / 10] x 250 = 2136. In this case, the memory after adjustment is greater than the value of maxMemory 2000. As a result, the value of ApplicationMaster is set to 2000 MB.
If the memory after adjustment is lower than the value of minMemory, the configuration does not take effect but the value is still printed on the backend server. This value is provided as the reference for adjusting the value of minMemory.
