Submitting a Task Using the YARN Client
This section guides users to use a Yarn client in an O&M or service scenario.
Service component users have been created by the MRS cluster administrator. In a cluster in security mode, machine-machine users need to download the keytab file. A human-machine user must change the password upon the first login. In a cluster in normal mode, you do not need to download the keytab file or change the password.
- Install the client. If the client has been installed, skip this step.
For example, if the installation directory is /opt/client. The client directory path used in the following steps is only an example. Replace it with your actual installation directory path.
For details about how to download and install the cluster client, see Installing an MRS Cluster Client.
- Log in to the node where the client is installed as the client installation user.
- Run the following command to go to the client installation directory:
cd /opt/client - Run the following command to configure environment variables:
source bigdata_env
- If Kerberos authentication is enabled for the cluster (in security mode), run the following command to authenticate the user. If Kerberos authentication is disabled for the cluster (in normal mode), user authentication is not required. In this case, skip this step.
kinit Component service user - Run the YARN command. For example, run the following command to view all applications in the YARN cluster:
yarn application -list
The command output is as follows:
Total number of applications (application-types: [], states: [SUBMITTED, ACCEPTED, RUNNING] and tags: []):2 Application-Id Application-Name Application-Type User Queue-User Queue State Final-State Progress Tracking-URL application_1749532996066_0002 default-worker yarn-service hetuserver hetuserver default RUNNING UNDEFINED 100% N/A application_1749532996066_0001 default-coordinator yarn-service hetuserver hetuserver default RUNNING UNDEFINED 100% N/A
Helpful Links
- If an error occurs and the process terminates when you run the YARN client command to query historical jobs, resolve the issue by referring to An Error Is Reported When a YARN Client Command Is Used to Query Historical Jobs.
- If the YARN ResourceManager reports a "connection refused" error when requesting a job submission and the configured YARN port is 8032, resolve the issue by referring to Incorrect Port Information of the Yarn Client Causes Error "connection refused" After a Task Is Submitted.
- The following are common problems encountered when you use the YARN client:
