MapReduce Optimization Configuration for Multiple CPU Cores
Optimization can be performed when the number of CPU cores is large, for example, the number of CPU cores is three times the number of disks.
You can set the following parameters in either of the following ways:
- Configuration on the server:
On the All Configurations page of the Yarn service, enter a parameter name in the search box. For details, see Modifying Cluster Service Configuration Parameters.
 - Configuration on the client:
    Modify the corresponding configuration file on the client.
      - Path of configuration files on the HDFS client: Client installation directory/HDFS/hadoop/etc/hadoop/hdfs-site.xml
- Path of configuration files on the Yarn client: Client installation directory/HDFS/hadoop/etc/hadoop/yarn-site.xml.
- Path of configuration files on the MapReduce client: Client installation directory/HDFS/hadoop/etc/hadoop/mapred-site.xml.
        Configuration  |
        Description  |
        Parameter  |
        Default Value  |
        Server/Client  |
        Impact  |
        Remarks  |
        Number of slots in a node container  |
        The combination of the following parameters determines the number of concurrent tasks (Map and Reduce tasks) of each node:
        yarn.nodemanager.resource.memory-mb
       You need to configure this parameter on FusionInsight Manager.  |
        16384  |
        Server  |
        If data needs to be read from and written into disks for all tasks (Map/Reduce tasks), a disk may be accessed by multiple processes at the same time, which leads to poor disk I/O performance. To ensure disk I/O performance, the number of concurrent access requests from a client to a disk cannot exceed 3.  |
        The maximum number of concurrent containers must be [2.5 x Number of disks configured in Hadoop].  |
        mapreduce.map.memory.mb
         You need to set this parameter in the configuration file on the client in the Client installation directory/HDFS/hadoop/etc/hadoop/mapred-site.xml path.  |
        4096  |
        Client  |
        mapreduce.reduce.memory.mb
        4096  |
        Client  |
        Map output and compression  |
        The Map task output before being written into disks can be compressed. This can save disk space, offer faster data write, and reduce the data traffic delivered to Reducer. You need to configure the following parameters on the client:
        mapreduce.map.output.compress
        true  |
        Client  |
        The disk I/O is the bottleneck. Therefore, use a compression algorithm with a high compression rate.  |
        Snappy is used. The benchmark test results show that Snappy delivers high performance and efficiency.  |
        mapreduce.map.output.compress.codec
        org.apache.hadoop.io.compress.Lz4Codec  |
        Client  |
        Spills  |
        mapreduce.map.sort.spill.percent  |
        0.8  |
        Client  |
        Disk I/Os are the bottleneck. You can set the value of mapreduce.task.io.sort.mb to minimize the memory spilled to the disk.  |
        Data packet size  |
        When the HDFS client writes data to a data node, the data will be accumulated until a packet is generated. Then, the packet is transmitted over the network. dfs.client-write-packet-size specifies the data packet size. It can be specified by each job.  |
         You need to set this parameter in the configuration file on the client in the Client installation directory/HDFS/hadoop/etc/hadoop/hdfs-site.xml/ path.  |
        262144  |
        Client  |
        The data node receives data packets from the HDFS client and writes data into disks through single threads. When disks are in the concurrent write state, increasing the data packet size can reduce the disk seek time and improve the I/O performance.  |
        dfs.client-write-packet-size = 262144  |
