Updated on 2025-11-13 GMT+08:00
Optimization for Unstable HDFS Network
Clients probably encounter running errors when the network is not stable. You can adjust the following parameter values to improve the running efficiency.
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose Cluster > Services > HDFS > Configurations > All Configurations.
  3. Search for the following parameters and change their values as required.
    Table 1 Parameters
    Default Value
    ha.health-monitor.rpc-timeout.ms
    Timeout interval during the NameNode health check performed by ZKFC. Increasing this value can prevent dual active NameNodes and reduce the probability of application running exceptions on clients.
    Unit: millisecond. Value range: 30,000 to 3,600,000
    180,000
    ipc.client.connect.max.retries.on.timeouts
    Number of retry times when the socket connection between a server and a client times out.
    Value range: 1 to 256
    45
    ipc.client.connect.timeout
    Timeout interval of the socket connection between a client and a server. Increasing the value of this parameter increases the timeout interval for setting up a connection.
    Unit: millisecond. Value range: 1 to 3,600,000
    20,000
  4. Save the settings. Restart the expired service or instance for the configuration to take effect.
