DBService Log Overview
Log Description
Log path: The default storage path of DBService log files is /var/log/Bigdata/dbservice.
- GaussDB: /var/log/Bigdata/dbservice/DB (GaussDB run log directory), /var/log/Bigdata/dbservice/scriptlog/gaussdbinstall.log (GaussDB installation log), and /var/log/gaussdbuninstall.log (GaussDB uninstallation log).
- HA: /var/log/Bigdata/dbservice/ha/runlog (HA run log directory) and /var/log/Bigdata/dbservice/ha/scriptlog (HA script log directory)
- DBServer: /var/log/Bigdata/dbservice/healthCheck (Directory of service and process health check logs)
/var/log/Bigdata/dbservice/scriptlog (run log directory), /var/log/Bigdata/audit/dbservice/ (audit log directory)
Log archive rule: The automatic DBService log compression function is enabled. By default, when the size of logs exceeds 1 MB, logs are automatically compressed into a log file named in the following format: <Original log file name>-[No.].gz. A maximum of 20 latest compressed files are reserved.
Log archive rules cannot be modified.
| Type | Log File Name | Description |
| DBServer run log | dbservice_serviceCheck.log | Run log file of the service check script |
| dbservice_processCheck.log | Run log file of the process check script | |
| backup.log | Run logs of backup and restoration operations (The DBService backup and restoration operations need to be performed.) | |
| checkHaStatus.log | Log file of HA check records | |
| cleanupDBService.log | Uninstallation log file (You need to uninstall DBService logs.) | |
| componentUserManager.log | Log file that records the adding and deleting operations on the database by users (Services that depend on DBService need to be added.) | |
| install.log | Installation log file | |
| preStartDBService.log | Pre-startup log file | |
| start_dbserver.log | DBServer startup operation log file (DBService needs to be started.) | |
| stop_dbserver.log | DBServer stop operation log file (DBService needs to be stopped.) | |
| status_dbserver.log | Log file of the DBServer status check (You need to execute the $DBSERVICE_HOME/sbin/status-dbserver.sh script.) | |
| modifyPassword.log | Run log file of changing the DBService password script. (You need to execute the $DBSERVICE_HOME/sbin/modifyDBPwd.sh script.) | |
| modifyDBPwd_yyyy-mm-dd.log | Run log file that records the DBService password change tool (You need to execute the $DBSERVICE_HOME/sbin/modifyDBPwd.sh script.) | |
| dbserver_switchover.log | Log for DBServer to execute the active/standby switchover script (the active/standby switchover needs to be performed) | |
| GaussDB run log | gaussdb.log | Log file that records database running information |
| gs_ctl-current.log | Log file that records operations performed by using the gs_ctl tool | |
| gs_guc-current.log | Log file that records operations, mainly parameter modification performed by using the gs_guc tool | |
| gaussdbinstall.log | GaussDB installation log file | |
| gaussdbuninstall.log | GaussDB uninstallation log file | |
| HA script run log | floatip_ha.log | Log file that records the script of floating IP addresses |
| gaussDB_ha.log | Log file that records the script of GaussDB resources | |
| ha_monitor.log | Log file that records the HA process monitoring information | |
| send_alarm.log | Alarm sending log file | |
| ha.log | HA run log file | |
| DBService audit log | dbservice_audit.log | Audit log file that records DBService operations, such as backup and restoration operations |
Log Level
Table 2 describes the log levels supported by DBService. The priorities of log levels are ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Log Format
The following table lists the DBService log formats.
| Type | Format | Example |
| Run log | [<yyyy-MM-dd HH:mm:ss>] <Log level>: [< Name of the script that generates the log: Line number >]: < Message in the log> | [2020-12-19 15:56:42] INFO [postinstall.sh:653] Is cloud flag is false. (main) |
| Audit log | [<yyyy-MM-dd HH:mm:ss,SSS>] UserName:<Username> UserIP:<User IP address> Operation:<Operation content> Result:<Operation results> Detail:<Detailed information> | [2020-05-26 22:00:23] UserName:omm UserIP:192.168.10.21 Operation:DBService data backup Result: SUCCESS Detail: DBService data backup is successful. |
