Flink Log Overview
Log Description
- Run logs of a Flink job: ${BIGDATA_DATA_HOME}/hadoop/data${i}/nm/containerlogs/application_${appid}/container_{$contid}
      The logs of executing tasks are stored in the preceding path. After the execution is complete, the Yarn configuration determines whether these logs are gathered to the HDFS directory.
 - FlinkResource run logs: /var/log/Bigdata/flink/flinkResource
 - Run logs related to FlinkServer HA scripts (MRS 3.2.0 or later): /var/log/Bigdata/audit/flink/flinkserver/ha
Log archive rules:
- By default, service logs are backed up each time when the log size reaches 20 MB. A maximum of 20 logs can be reserved without being compressed.
 - You can set the log size and number of compressed logs on the Manager page or modify the corresponding configuration items in log4j-cli.properties, log4j.properties, and log4j-session.properties in Client installation directory/Flink/flink/conf/ on the client.
Table 1 FlinkResource log list Type
Name
checkService.log
Health check log
kinit.log
Initialization log
postinstall.log
Service installation log
prestart.log
Prestart script log
start.log
Startup log
 - FlinkServer service logs, HA-related logs, and audit logs.
- By default, FlinkServer service logs, HA-related logs, and audit logs are backed up each time when the log size reaches 100 MB. The service logs are stored for a maximum of 30 days, and audit logs are stored for a maximum of 90 days.
Table 2 FlinkServer log list Type
Name
FlinkServer run logs
checkService.log
Health check log
checkFlinkServer.log
Health check log of FlinkServer
localhost_access_log..yyyy-mm-dd.txt
URL log of FlinkServer
start_thrift_server.out
Thrift server startup log
thrift_server_thriftServer_xxx.log.last
cleanup.log
Cleanup log file for instance installation and uninstallation
flink-omm-client-IP.log
Job startup log
flinkserver_yyyymmdd-x.log.gz
Service archive log
flinkserver.log
Service log
flinkserver---pidxxxx-gc.log.x.current
GC log
kinit.log
Initialization log
postinstall.log
prestart.log
Prestart script log
start.log
Startup log
stop.log
Stop log
catalina.yyyy-mm-dd.log
Tomcat run log
catalina.out
host-manager.yyyy-mm-dd.log
localhost.yyyy-mm-dd.log
Run log file related to FlinkServer HA scripts (MRS 3.2.0 or later)
ha.log
HA run log
ha_monitor.log
HA process monitoring log
floatip_ha.log
Floating IP address resource script log
rcommflinkserver.log
FlinkServer resource script log
checkHaStatus.log
HA process log
checknode.log
HA health status log
rs-sendAlarm.log
HA alarm sending log
flink_roll.log
FlinkServer active/standby switchover log (active/standby switchover required)
FlinkServer audit logs
flinkserver_audit_yyyymmdd-x.log.gz
Audit archive log
flinkserver_audit.log
Audit log
Stack information log (MRS 3.2.0 or later)
threadDump-<DATE>.log
Log printed when instances are restarted or stopped
Log Level
Table 3 describes the log levels supported by Flink. The priorities of log levels are ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
        Level  |
        Description  |
        ERROR  |
        Error information about the current event processing  |
        WARN  |
        Exception information about the current event processing  |
        INFO  |
        Normal running status information about the system and events  |
        DEBUG  |
        System information and system debugging information  |
To modify log levels, perform the following steps:
- Go to the All Configurations page of Flink by referring to Modifying Cluster Service Configuration Parameters.
 - On the menu bar on the left, select the log menu of the target role.
 - Select a desired log level.
 - Save the configuration. In the displayed dialog box, click OK to make the configurations take effect.
   - After the configuration is complete, you do not need to restart the service. Download the client again for the configuration to take effect.
 - You can also change the configuration items corresponding to the log level in log4j-cli.properties, log4j.properties, and log4j-session.properties in Client installation directory/Flink/flink/conf/ on the client.
 - When a job is submitted using a client, a log file is generated in the log folder on the client. The default umask value is 0022. Therefore, the default log permission is 644. To change the file permission, you need to change the umask value. For example, to change the umask value of user omm:
- Add umask 0026 to the end of the /home/omm/.baskrc file.
 - Run the source /home/omm/.baskrc command to make the file permission take effect.
Log Format
        Type  |
        Format  |
        Example  |
        Run log  |
        <yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>  |
        2019-06-27 21:30:31,778 | INFO | [flink-akka.actor.default-dispatcher-3] | TaskManager container_e10_1498290698388_0004_02_000007 has started. | org.apache.flink.yarn.YarnFlinkResourceManager (FlinkResourceManager.java:368)  |
