Flume Common Configuration Parameters
Some parameters can be configured on Manager.
This section describes how to configure the sources, channels, and sinks of Flume, and modify the configuration items of each module.
For MRS 3.x or later, log in to FusionInsight Manager and choose Cluster > Services > Flume. On the displayed page, click the Configuration Tool tab, select and drag the source, channel, and sink to be used to the GUI on the right, and double-click them to configure corresponding parameters. Parameters such as channels and type are configured only in the client configuration file properties.properties, the path of which is Flume client installation directory/fusioninsight-flume-Flume version/conf/properties.properties.
You must input encrypted information for some configurations. For details on how to encrypt information, see Using the Encryption Tool of the Flume Client.
Common Source Configurations
- Avro Source
An Avro source listens to the Avro port, receives data from the external Avro client, and places data into configured channels. Table 1 lists common configurations.
Figure 1 Avro Source
Table 1 Common configurations of an Avro source Parameter
Default Value
channels
Specifies the channel connected to the source. Multiple channels can be configured. Use spaces to separate them.
In a single proxy process, sources and sinks are connected through channels. A source instance corresponds to multiple channels, but a sink instance corresponds only to one channel.
The format is as follows:
<Agent >.sources.<Source>.channels = <channel1> <channel2> <channel3>...
<Agent >.sinks.<Sink>.channels = <channel1>
This parameter can be configured only in the properties.properties file.
type
avro
Specifies the type, which is set to avro. The type of each source is a fixed value.
bind
Specifies the host name or IP address associated with the source.
port
Specifies the bound port number.
ssl
false
Specifies whether to use SSL encryption.
- true
- false
truststore-type
JKS
Specifies the Java trust store type. Set this parameter to JKS or other truststore types supported by Java.
truststore
Specifies the Java trust store file.
truststore-password
Specifies the Java trust store password.
keystore-type
JKS
Specifies the key storage type. Set this parameter to JKS or other truststore types supported by Java.
keystore
Specifies the key storage file.
keystore-password
Specifies the key storage password.
- SpoolDir Source
A SpoolDir source monitors and transmits new files that have been added to directories in quasi-real-time mode. Common configurations are as follows:
Figure 2 SpoolDir Source
Table 2 Common configurations of a SpoolDir source Parameter
Default Value
channels
type
spooldir
Type, which is set to spooldir.
monTime
0 (Disabled)
Specifies the thread monitoring threshold. When the update time exceeds the threshold, the source is restarted. Unit: second
spoolDir
Specifies the monitoring directory.
fileSuffix
.COMPLETED
Specifies the suffix added after file transmission is complete.
deletePolicy
never
Specifies the source file deletion policy after file transmission is complete. The value can be either never or immediate.
ignorePattern
Specifies the regular expression of a file to be ignored.
trackerDir
.flumespool
Specifies the metadata storage path during data transmission.
batchSize
1000
Specifies the source transmission granularity.
decodeErrorPolicy
FAIL
Specifies the code error policy. This parameter can be configured only in the properties.properties file.
The value can be FAIL, REPLACE, or IGNORE.
FAIL: Generate an exception and fail the parsing.
REPLACE: Replace the characters that cannot be identified with other characters, such as U+FFFD.
IGNORE: Discard character strings that cannot be parsed.
NOTE:If a code error occurs in the file, set decodeErrorPolicy to REPLACE or IGNORE. Flume will skip the code error and continue to collect subsequent logs.
deserializer
LINE
Specifies the file parser. The value can be either LINE or BufferedLine.
- When the value is set to LINE, characters read from the file are transcoded one by one.
- When the value is set to BufferedLine, one line or multiple lines of characters read from the file are transcoded in batches, which delivers better performance.
deserializer.maxLineLength
2048
Specifies the maximum length for resolution by line, ranging from 0 to 2,147,483,647.
deserializer.maxBatchLine
Specifies the maximum number of lines for resolution by line. If multiple lines are set, maxLineLength must be set to a corresponding multiplier. For example, if maxBatchLine is set to 2, maxLineLength is set to 4096 (2048 x 2).
selector.type
replicating
Specifies the selector type. The value can be either replicating or multiplexing.
- replicating indicates that the same content is sent to each channel.
- multiplexing indicates that the content is sent only to certain channels according to the distribution rule.
interceptors
Specifies the interceptor.
The Spooling source ignores the last line feed character of each event when data is read by line. Therefore, Flume does not calculate the data volume counters used by the last line feed character.
- Kafka Source
A Kafka source consumes data from Kafka topics. Multiple sources can consume data of the same topic, and the sources consume different partitions of the topic. Common configurations are as follows:
Figure 3 Kafka Source
Table 3 Common configurations of a Kafka source Parameter
Default Value
channels
type
org.apache.flume.source.kafka.KafkaSource
Specifies the type, which is set to org.apache.flume.source.kafka.KafkaSource.
monTime
0 (Disabled)
nodatatime
0 (Disabled)
Specifies the alarm threshold. An alarm is triggered when the duration that Kafka does not release data to subscribers exceeds the threshold. Unit: second
batchSize
1000
Specifies the number of events written into a channel at a time.
batchDurationMillis
1000
Specifies the maximum duration of topic data consumption at a time, expressed in milliseconds.
keepTopicInHeader
false
Specifies whether to save topics in the event header. If topics are saved, topics configured in Kafka sinks become invalid.
- true
- false
keepPartitionInHeader
false
Specifies whether to save partition IDs in the event header. If partition IDs are saved, Kafka sinks write data to the corresponding partitions.
- true
- false
This parameter can be set only in the properties.properties file.
kafka.bootstrap.servers
Specifies the list of Broker addresses, which are separated by commas.
kafka.consumer.group.id
Specifies the Kafka consumer group ID.
kafka.topics
Specifies the list of subscribed Kafka topics, which are separated by commas (,).
kafka.topics.regex
Specifies the subscribed topics that comply with regular expressions. kafka.topics.regex has a higher priority than kafka.topics and will overwrite kafka.topics.
kafka.security.protocol
SASL_PLAINTEXT
Specifies the security protocol of Kafka. The value must be set to PLAINTEXT for clusters in which Kerberos authentication is disabled.
kafka.kerberos.domain.name
Specifies the value of default_realm of Kerberos in the Kafka cluster, which should be configured only for security clusters.
Other Kafka Consumer Properties
Specifies other Kafka configurations. This parameter can be set to any consumption configuration supported by Kafka, and the .kafka prefix must be added to the configuration.
- Taildir Source
A Taildir source monitors file changes in a directory and automatically reads the file content. In addition, it can transmit data in real time. Table 4 lists common configurations.
Figure 4 Taildir Source
Table 4 Common configurations of a Taildir source Parameter
Default Value
channels
type
taildir
Specifies the type, which is set to taildir.
filegroups
Specifies the group name of a collection file directory. Group names are separated by spaces.
filegroups.<filegroupName>.parentDir
Specifies the parent directory. The value must be an absolute path.
filegroups.<filegroupName>.filePattern
Specifies the relative file path of the file group's parent directory. Directories can be included and regular expressions are supported. It must be used together with parentDir.
positionFile
headers.<filegroupName>.<headerKey>
Specifies the key-value of an event when data of a group is being collected.
byteOffsetHeader
false
Specifies whether each event header should contain the location information about the event in the source file. The location information is saved in the byteoffset variable.
skipToEnd
false
Specifies whether Flume can locate the latest location of a file and read the latest data after restart.
idleTimeout
120000
Specifies the idle duration during file reading, expressed in milliseconds. If the file data is not changed in this idle period, the source closes the file. If data is written into this file after it is closed, the source opens the file and reads data.
writePosInterval
3000
Specifies the interval for writing metadata to a file, expressed in milliseconds.
batchSize
1000
Specifies the number of events written to the channel in batches.
monTime
0 (Disabled)
- Http Source
An HTTP source receives data from an external HTTP client and sends the data to the configured channels. Table 5 lists common configurations.
Figure 5 Http Source
Table 5 Common configurations of an HTTP source Parameter
Default Value
channels
Specifies the channel connected to the source. Multiple channels can be configured. This parameter can be set only in the properties.properties file.
type
http
Specifies the type, which is set to http. This parameter can be set only in the properties.properties file.
bind
Specifies the name or IP address of the bound host.
port
Specifies the bound port.
handler
org.apache.flume.source.http.JSONHandler
Specifies the message parsing method of an HTTP request. The following methods are supported:
- org.apache.flume.source.http.JSONHandler: JSON
- org.apache.flume.sink.solr.morphline.BlobHandler: BLOB
handler.*
Specifies handler parameters.
enableSSL
false
Specifies whether SSL is enabled in HTTP.
keystore
Specifies the keystore path set after SSL is enabled in HTTP.
keystorePassword
Specifies the keystore password set after SSL is enabled in HTTP.
Common Channel Configurations
- Memory Channel
A memory channel uses memory as the cache. Events are stored in memory queues. Table 6 lists common configurations.
Figure 6 Memory Channel
Table 6 Common configurations of a memory channel Parameter
Default Value
type
Specifies the type, which is set to memory. This parameter can be set only in the properties.properties file.
capacity
10000
Specifies the maximum number of events cached in a channel.
transactionCapacity
1000
Specifies the maximum number of events accessed each time.
channelfullcount
10
Specifies the channel full count. When the count reaches the threshold, an alarm is reported.
- File Channel
A file channel uses local disks as the cache. Events are stored in the folder specified by dataDirs. Table 7 lists common configurations.
Figure 7 File Channel
Table 7 Common configurations of a file channel Parameter
Default Value
type
Specifies the type, which is set to file. This parameter can be set only in the properties.properties file.
checkpointDir
${BIGDATA_DATA_HOME}/flume/checkpoint
Specifies the checkpoint storage directory.
dataDirs
${BIGDATA_DATA_HOME}/flume/data
Specifies the data cache directory. Multiple directories can be configured to improve performance. The directories are separated by commas (,).
maxFileSize
2146435071
Specifies the maximum size of a single cache file, expressed in bytes.
minimumRequiredSpace
524288000
Specifies the minimum idle space in the cache, expressed in bytes.
capacity
1000000
transactionCapacity
10000
channelfullcount
10
- Kafka Channel A Kafka channel uses a Kafka cluster as the cache. Kafka provides high availability and multiple copies to prevent data from being immediately consumed by sinks when Flume or Kafka Broker crashes. Table 10 Common configurations of a Kafka channel lists common configurations.Figure 8 Kafka Channel
Table 8 Common configurations of a Kafka channel Parameter
Default Value
type
Specifies the type, which is set to org.apache.flume.channel.kafka.KafkaChannel.
Specifies the list of Brokers in the Kafka cluster.
kafka.topic
flume-channel
Specifies the Kafka topic used by the channel to cache data.
flume
parseAsFlumeEvent
true
Specifies whether data is parsed into Flume events.
migrateZookeeperOffsets
true
Specifies whether to search for offsets in ZooKeeper and submit them to Kafka when there is no offset in Kafka.
kafka.consumer.auto.offset.reset
latest
Consumes data from the specified location when there is no offset.
kafka.producer.security.protocol
SASL_PLAINTEXT
Specifies the Kafka producer security protocol.
kafka.consumer.security.protocol
SASL_PLAINTEXT
Specifies the Kafka consumer security protocol.
Common Sink Configurations
- HDFS Sink
An HDFS sink writes data into HDFS. Table 9 lists common configurations.
Figure 9 HDFS Sink
Table 9 Common configurations of an HDFS sink Parameter
Default Value
channel
Specifies the channel connected to the sink. This parameter can be set only in the properties.properties file.
type
hdfs
Specifies the type, which is set to hdfs. This parameter can be set only in the properties.properties file.
monTime
0 (Disabled)
Specifies the thread monitoring threshold. When the update time exceeds the threshold, the sink is restarted. Unit: second
hdfs.path
Specifies the HDFS path.
hdfs.inUseSuffix
.tmp
Specifies the suffix of the HDFS file to which data is being written.
hdfs.rollInterval
30
Specifies the interval for file rolling, expressed in seconds. Set hdfs.fileCloseByEndEvent to false if you set this parameter.
hdfs.rollSize
1024
Specifies the size for file rolling, expressed in bytes. Set hdfs.fileCloseByEndEvent to false if you set this parameter.
hdfs.rollCount
10
Specifies the number of events for file rolling. Set hdfs.fileCloseByEndEvent to false if you set this parameter.
hdfs.idleTimeout
0
Specifies the timeout interval for closing idle files automatically, expressed in seconds.
hdfs.batchSize
1000
Specifies the number of events written into HDFS at a time.
hdfs.kerberosPrincipal
Specifies the Kerberos username for HDFS authentication. This parameter is not required for a cluster in which Kerberos authentication is disabled.
hdfs.kerberosKeytab
Specifies the Kerberos keytab of HDFS authentication. This parameter is not required for a cluster in which Kerberos authentication is disabled.
true
Specifies whether to close the file when the last event is received.
hdfs.batchCallTimeout
Specifies the timeout control duration each time events are written into HDFS, expressed in milliseconds.
If this parameter is not specified, the timeout duration is controlled when each event is written into HDFS. When the value of hdfs.batchSize is greater than 0, configure this parameter to improve the performance of writing data into HDFS.
NOTE:The value of hdfs.batchCallTimeout depends on hdfs.batchSize. A greater hdfs.batchSize requires a larger hdfs.batchCallTimeout. If the value of hdfs.batchCallTimeout is too small, writing events to HDFS may fail.
serializer.appendNewline
true
Specifies whether to add a line feed character (\n) after an event is written to HDFS. If a line feed character is added, the data volume counters used by the line feed character will not be calculated by HDFS sinks.
- Avro Sink
An Avro sink converts events into Avro events and sends them to the monitoring ports of the hosts. Table 10 lists common configurations.
Figure 10 Avro Sink
Table 10 Common configurations of an Avro sink Parameter
Default Value
channel
type
Specifies the type, which is set to avro. This parameter can be set only in the properties.properties file.
hostname
port
Specifies the monitoring port.
batch-size
1000
Specifies the number of events sent in a batch.
ssl
false
truststore-type
JKS
truststore
truststore-password
keystore-type
JKS
keystore
keystore-password
- HBase Sink
An HBase sink writes data into HBase. Table 11 lists common configurations.
Figure 11 HBase Sink
Table 11 Common configurations of an HBase sink Parameter
Default Value
channel
type
Specifies the type, which is set to hbase. This parameter can be set only in the properties.properties file.
table
Specifies the HBase table name.
monTime
0 (Disabled)
columnFamily
Specifies the HBase column family.
batchSize
1000
Specifies the number of events written into HBase at a time.
kerberosPrincipal
Specifies the Kerberos username for HBase authentication. This parameter is not required for a cluster in which Kerberos authentication is disabled.
kerberosKeytab
Specifies the Kerberos keytab of HBase authentication. This parameter is not required for a cluster in which Kerberos authentication is disabled.
- Kafka Sink
A Kafka sink writes data into Kafka. Table 12 lists common configurations.
Figure 12 Kafka Sink
Table 12 Common configurations of a Kafka sink Parameter
Default Value
channel
type
Specifies the type, which is set to org.apache.flume.sink.kafka.KafkaSink.
Specifies the list of Kafka Brokers, which are separated by commas.
monTime
0 (Disabled)
kafka.topic
default-flume-topic
Specifies the topic where data is written.
flumeBatchSize
1000
Specifies the number of events written into Kafka at a time.
SASL_PLAINTEXT
Specifies the Kafka domain name. This parameter is mandatory for a security cluster. This parameter can be set only in the properties.properties file.
Other Kafka Producer Properties
Specifies other Kafka configurations. This parameter can be set to any production configuration supported by Kafka, and the .kafka prefix must be added to the configuration.
