Kafka User Permissions
For clusters with Kerberos authentication enabled, using Kafka requires relevant permissions. MRS clusters can grant the use permission of Kafka to different users.
Table 1 lists the default Kafka user groups.
   Kafka supports two types of authentication plug-ins: Kafka open source authentication plug-in and Ranger authentication plug-in.
This section describes the user permission management based on the Kafka open source authentication plug-in. For details about how to use the Ranger authentication plug-in, see Adding a Ranger Access Permission Policy for Kafka.
        User Group  |
        Description  |
        kafkaadmin  |
        Kafka administrator group. Users in this group have the permissions to create, delete, read, and write all topics, and authorize other users.  |
        kafkasuperuser  |
        Kafka super user group. Users in this group have the permissions to read and write all topics.  |
        kafka  |
        Kafka common user group. Users in this group can access a topic only when they are granted with the read and write permissions of the topic by a user in the kafkaadmin group.  |
- You have installed the Kafka client.
 - A user in the kafkaadmin group has been prepared.
- Log in to FusionInsight Manager. For details, see Accessing FusionInsight Manager. Choose Cluster > Services > ZooKeeper > Instances.
 - View the IP addresses of the ZooKeeper role instance.
Record the IP address of any ZooKeeper instance.
 - Prepare the client based on service requirements. Log in to the node where the client is installed. For details, see Using an MRS Client.
 - Run the following command to switch to the client installation directory, for example, /opt/client/Kafka/kafka/bin.
cd /opt/client/Kafka/kafka/bin
 - Run the following command to configure environment variables:
source /opt/client/bigdata_env
 - Run the following command to authenticate the user(skip this step in normal mode):
kinit Component service user
 - The following lists the common kafka-acl.sh commands used for user authorization:
- View the permission control list of a topic:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --list --topic <Topic name>
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --list --topic <topic name>
 - Add the Producer permission for a user:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --add --allow-principal User:<Username> --producer --topic <Topic name>
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --add --allow-principal User:<username> --producer --topic <topic name>
 - Assign the Producer permission to a user in batches.
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --add --allow-principal User:<Username> --producer --topic <Topic name> --resource-pattern-type prefixed
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --add --allow-principal User:<username> --producer --topic <topic name>--resource-pattern-type prefixed
 - Remove the Producer permission from a user:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --remove --allow-principal User:<Username> --producer --topic <Topic name>
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --remove --allow-principal User:<username> --producer --topic <topic name>
 - Delete the Producer permission of a user in batches:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --remove --allow-principal User:<Username> --producer --topic <Topic name> --resource-pattern-type prefixed
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --remove --allow-principal User:<username> --producer --topic <topic name>--resource-pattern-type prefixed
 - Add the Consumer permission for a user:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --add --allow-principal User:<Username> --consumer --topic <Topicname> --group <Consumer group name>
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --add --allow-principal User:<username> --consumer --topic <topicname> --group <consumer group name>
 - Add consumer permissions to a user in batches:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --add --allow-principal User:<Username> --consumer --topic <Topic name> --group <Consumer group name> --resource-pattern-type prefixed
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --add --allow-principal User:<username> --consumer --topic <topicname> --group <consumer group name> --resource-pattern-type prefixed
 - Remove the consumer permission from a user:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --remove --allow-principal User:<Username> --consumer --topic <Topic name> --group <Consumer group name>
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --remove --allow-principal User:<username> --consumer --topic <topic name> --group <consumer group name>
 - Delete the consumer permission of a user in batches:
./kafka-acls.sh --authorizer-properties zookeeper.connect=<Service IP address of any ZooKeeper node:2181/kafka > --remove --allow-principal User:<Username> --consumer --topic <Topic name> --group <Consumer group name> --resource-pattern-type prefixed
./kafka-acls.sh --bootstrap-server <IP address of the Kafkacluster:21007> --command-config ../config/client.properties --remove --allow-principal User:<username> --consumer --topic <topicname> --group <consumer group name> --resource-pattern-type prefixed
