Managing Kafka Topics
You can manage Kafka topics on a cluster client based on service requirements. Management permission is required for clusters with Kerberos authentication enabled.
You have installed the Kafka client.
- Access the ZooKeeper instance page.
Log in to FusionInsight Manager. For details, see Accessing FusionInsight Manager. Choose Cluster > Services > ZooKeeper > Instance.
- View the IP addresses of the ZooKeeper role instance.
Record any IP address of the ZooKeeper instance.
- Prepare the client based on service requirements. Log in to the node where the client is installed.For details, see Using an MRS Client.
- Run the following command to switch to the client installation directory, for example, /opt/client/Kafka/kafka/bin.
cd /opt/client/Kafka/kafka/bin
- Run the following command to configure environment variables:
source /opt/client/bigdata_env
- Run the following command to perform user authentication (skip this step in normal mode):
kinit Component service user
- Use kafka-topics.sh to manage Kafka topics.
- Creating a topic:
./kafka-topics.sh --create --topic topic name --partitions number of partitions occupied by the topic--replication-factor number of replicas of the topic--zookeeper IP address of any ZooKeeper node:clientPort/kafka
./kafka-topics.sh --create --topic topic name --partitions number of partitions occupied by the topic--replication-factor number of replicas of the topic --bootstrap-server IP address of the Kafkacluster:21007 --command-config ../config/client.properties
- List of topics:
- ./kafka-topics.sh --list --zookeeper service IP address of any ZooKeeper node:clientPort/kafka
- ./kafka-topics.sh --list --bootstrap-server IP address of the Kafkacluster:21007 --command-config ../config/client.properties
- Viewing the topic:
- ./kafka-topics.sh --describe --zookeeper service IP address of any ZooKeeper node:clientPort/kafka --topic topic name
- ./kafka-topics.sh --describe --bootstrap-server IP address of the Kafkacluster:21007 --command-config ../config/client.properties --topic topic name
- Modifying a topic:
- ./kafka-topics.sh --alter --topic topic name--config configuration item=configuration value --zookeeper service IP address of any ZooKeeper node:clientPort/kafka
- Expanding partitions:
- ./kafka-topics.sh --alter --topic topic name --zookeeper service IP address of any ZooKeeper node:clientPort/kafka --command-config Kafka/kafka/config/client.properties --partitions number of partitions after the expansion
- ./kafka-topics.sh --alter --topic topic name --bootstrap-server IP address of the Kafka cluster:21007 --command-config Kafka/kafka/config/client.properties --partitions number of partitions after the expansion
- Deleting a topic
- ./kafka-topics.sh --delete --topic topic name --zookeeper Service IP address of any ZooKeeper node:clientPort/kafka
- ./kafka-topics.sh --delete --topic topic name--bootstrap-server IP address of the Kafka cluster:21007 --command-config ../config/client.properties
- Creating a topic:
