On this page
Hue Log Overview
Log Description
Log paths: The default paths of Hue logs are /var/log/Bigdata/hue (for storing run logs) and /var/log/Bigdata/audit/hue (for storing audit logs).
Log archive rules: The automatic compression and archiving function of the Hue logs is enabled. By default, when the size of a log file (access.log, error.log, runcpserver.log, or hue-audits.log) exceeds 5 MB, logs are automatically compressed. A maximum of 20 latest compressed files are reserved. The number of compressed files and compression threshold can be configured.
Table 1 Hue log list
Type
Log File Name
Run log
access.log
Access log file
error.log
Error log file
gsdb_check.log
Log file of the GaussDB check information
kt_renewer.log
Log file of Kerberos authentication
kt_renewer.out.log
Log file of the abnormal Kerberos authentication logs
runcpserver.log
Log file of operation records
runcpserver.out.log
Log file of process running exceptions
supervisor.log
Log file of process startup
supervisor.out.log
Log file of process startup exceptions
dbDetail.log
Log file of database initialization
initSecurityDetail.log
Download initialization log file of the Keytab file
postinstallDetail.log
Work log file generated after the Hue service is installed
prestartDetail.log
Prestart log file
statusDetail.log
Log file of the Hue health status
startDetail.log
Startup log
get-hue-ha.log
Log file of the Hue HA status
hue-ha-status.log
Log file of the Hue HA status monitoring
get-hue-health.log
hue-health-check.log
Log file of the Hue health check
hue-refresh-config.log
Log file of the Hue configuration update
hue-script-log.log
Log file of the Hue operations on the Manager console
hue-service-check.log
Log file of the Hue service status monitoring
db_pwd.log
Log that records the changes of the password for Hue to connect to the DBService database
modifyDBPwd_Date.log
watch_config_update.log
Parameter update log file
Audit log
hue-audits.log
Audit log file
Log Level
Table 2 describes the log levels supported by Hue.
Levels of logs are ERROR, WARN, INFO, and DEBUG from the highest to the lowest priority. Run logs of equal or higher levels are recorded. The higher the specified log level, the fewer the logs recorded.
Table 2 Log levels
Level
ERROR
Logs of this level record error information about system running.
WARN
Logs of this level record exception information about the current event processing.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record the system information and system debugging information.
To modify log levels, perform the following operations:
  1. Go to the All Configurations page of the Hue service by referring to Modifying Cluster Service Configuration Parameters.
  2. In the navigation tree on the left, select Log corresponding to the role to be modified.
  3. Select the log level to be changed on the right.
  4. Save the configuration. In the displayed dialog box, click OK to make the configurations take effect.
  5. Restart the service or instance whose configuration has expired for the configuration to take effect.
Log Format
The following table lists the Hue log formats:
Table 3 Log formats
Type
Format
Example
Run log
<dd-MM-yy HH:mm:ss,SSS><Location where the log event occurs><Log level><Message in the log>
[03/Nov/2014 11:57:19 ] middleware | INFO | Unloading MimeTypeJSFileFixStreamingMiddleware.
<Log level><Time format><yyyy-MM-dd HH:mm:ss,SSS><Location where the log event occurs><Message in the log>
INFO : CST 2014-11-06 11:22:52 hue-ha-status.sh : update 4 <= 15:myHostName=10.0.0.250 ACTIVE=10.0.0.250
Audit log
<UserName><yyyy-MM-dd HH:mm:ss,SSS>< Audit operation description> <Resource parameter> <URL> <Whether to allow> <Audit operation> <IP address>
{"username": "admin", "eventTime": "2014-11-06 10:28:34", "operationText": "Successful login for user: admin", "service": "accounts", "url": "/accounts/login/", "allowed": true, "operation": "USER_LOGIN", "ipAddress": "10.0.0.250"}
