DESCRIBE OUTPUT
Syntax
DESCRIBE OUTPUT statement_name
This statement is used to list the output columns of the prepared statement, including the column name (or alias), catalog, schema, table name, type, type size (in bytes), and a boolean value indicating whether the column is an alias.
Example
--PREPARE my_select1 FROM SELECT * FROM fruit;
  DESCRIBE OUTPUT my_select1;
--PREPARE my_select2 FROM SELECT count(*) as my_count, 1+2 FROM fruit;
  DESCRIBE OUTPUT my_select2;
--PREPARE my_create FROM CREATE TABLE foo AS SELECT * FROM fruit;
  DESCRIBE OUTPUT my_create;
