DESCRIBE FORMATTED COLUMNS
Syntax
DESCRIBE FORMATTED [db_name.]table_name [PARTITION partition_spec] col_name
This statement is used to describe the column information of a table or partition and collect statistics on the columns of specified tables or partitions.
Example
describe formatted show_table1 a;
  Describe Formatted Column
 col_name             a
 data_type            integer
 min
 max
 num_nulls
 distinct_count       0
 avg_col_len
 max_col_len
 num_trues
 num_falses
 comment
(1 row)
