Updated on 2024-10-25 GMT+08:00
Common Flink SQL Syntax
SELECT and WHERE
Filter using the WHERE clause.
  • Syntax:
    SELECT select_list FROM table_expression [ WHERE boolean_expression ]
  • Example:
    SELECT price + tax FROM Orders WHERE id = 10
WITH
WITH provides a way to write auxiliary statements for use in a larger query. These statements, which are often referred to as Common Table Expression (CTE), can be thought of as defining temporary views that exist just for one query.
  • Syntax:
    WITH <with_item_definition> [ , ... ]
    SELECT ... FROM ...;
    <with_item_defintion>:
    with_item_name (column_name[, ...n]) AS ( <select_query> )
  • Example:
    Define a common table expression orders_with_total and use it in a GROUP BY query.
    WITH orders_with_total AS (
        SELECT order_id, price + tax AS total
        FROM Orders
    SELECT order_id, SUM(total)
    FROM orders_with_total
    GROUP BY order_id;
Window Aggregation
Queries with a group by window aggregation will compute a single result row per group.
  • Syntax:
    SELECT ...
    FROM <windowed_table> -- relation applied windowing TVF
    GROUP BY window_start, window_end, …
  • Example:
    SELECT window_start, window_end, SUM(price)
    FROM TABLE(
    TUMBLE(TABLE Bid, DESCRIPTOR(bidtime), INTERVAL '10' MINUTES))
    GROUP BY window_start, window_end;
Window Deduplication
Window Deduplication is a special deduplication which removes rows that duplicate over a set of columns, keeping the first one or the last one for each window and partitioned keys.
  • Syntax:
    SELECT [column_list]
    FROM (
    SELECT [column_list],
    ROW_NUMBER() OVER (PARTITION BY window_start, window_end [, col_key1...]
    ORDER BY time_attr [asc|desc]) AS rownum
    FROM table_name) -- relation applied windowing TVF
    WHERE (rownum = 1 | rownum <=1 | rownum < 2) [AND conditions]
  • Example:
    SELECT *
    FROM (
    SELECT bidtime, price, item, supplier_id, window_start, window_end,
    ROW_NUMBER() OVER (PARTITION BY window_start, window_end ORDER BY bidtime DESC) AS rownum
    FROM TABLE(
    ) WHERE rownum <= 1;
Top-N
Top-N queries ask for the N smallest or largest values ordered by columns.
  • Syntax:
    FROM (
    ROW_NUMBER() OVER ([PARTITION BY col1[, col2...]]
    ORDER BY col1 [asc|desc][, col2 [asc|desc]...]) AS rownum
    FROM table_name)
    WHERE rownum <= N [AND conditions]
  • Example:
    CREATE TABLE ShopSales (
    product_id   STRING,
    category     STRING,
    product_name STRING,
    sales        BIGINT
    ) WITH (...);
    SELECT *
    FROM (
    SELECT *,
    ROW_NUMBER() OVER (PARTITION BY category ORDER BY sales DESC) AS row_num
    FROM ShopSales)
    WHERE row_num <= 5
