Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using HetuEngine/
HetuEngine Common SQL Syntax Description/
Auxiliary Command Syntax
- USE
- SET SESSION
- RESET SESSION
- DESCRIBE
- DESCRIBE FORMATTED COLUMNS
- DESCRIBE DATABASE| SCHEMA
- DESCRIBE INPUT
- DESCRIBE OUTPUT
- EXPLAIN
- EXPLAIN ANALYZE
- REFRESH CATALOG
- REFRESH SCHEMA
- REFRESH TABLE
- ANALYZE
- CALL
- PREPARE
- DEALLOCATE PREPARE
- EXECUTE
- VERIFY
Parent topic: HetuEngine Common SQL Syntax Description
