Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using HetuEngine/
HetuEngine Common SQL Syntax Description/
DDL Syntax/
SHOW CREATE VIEW
SHOW CREATE VIEW
Syntax
SHOW CREATE VIEW view_name
This statement is used to display the SQL creation statement of a specified data view.
Example
To display the SQL statement that can be used to create the order_view view:
SHOW CREATE VIEW test_view; Create View --------------------------------------- CREATE VIEW hive.default.test_view AS SELECT orderkey , orderstatus , (totalprice / 4) quarter FROM orders (1 row)
Parent topic: DDL Syntax
