Conversion Functions
cast Conversion Function
HetuEngine implicitly converts numeric and character values to the correct type. HetuEngine does not convert between character and numeric types. For example, if a query expects a value of the varchar type, HetuEngine does not automatically convert a value of the bigint type to a value of the varchar type.
Values can be explicitly converted to the specified type, if necessary.
  • cast(value AS type) → type
    Explicitly converts the type of a value. You can convert a value of the varchar type to the numeric type, or vice versa.
    select cast('186' as int );
    select cast(186 as varchar);
  • try_cast(value AS type) → type
    It is similar to cast(). The difference is that null is returned if the conversion fails.
    select try_cast(1860 as tinyint);
     _col0
      NULL
    (1 row)
When a number overflows or a null value is converted, null is returned. However, when the conversion fails, an error is reported.
Example: select try_cast(186 as date);
Cannot cast integer to date
Format
  • format(format, args...) → varchar
    Description: Formats a string in the format specified by the format string and returns the formatted string.
    SELECT format('%s%%',123);-- '123%'
    SELECT format('%.5f',pi());-- '3.14159'
    SELECT format('%03d',8);-- '008'
    SELECT format('%,.2f',1234567.89);-- '1,234,567.89'
    SELECT format('%-7s,%7s','hello','world');-- 'hello  ,  world'
    SELECT format('%2$s %3$s %1$s','a','b','c');-- 'b c a'
    SELECT format('%1$tA, %1$tB %1$te, %1$tY',date'2006-07-04');-- 'Tuesday, July 4, 2006
  • format_number(number) → varchar
    Description: Returns a string formatted by unit symbol.
    SELECT format_number(123456); -- '123K'
    SELECT format_number(1000000); -- '1M'
Data Size
The parse_presto_data_size function supports the following units:
Unit
Value
B
Bytes
kB
Kilobytes
1024
MB
Megabytes
10242
GB
Gigabytes
10243
TB
Terabytes
10244
PB
Petabytes
10245
EB
Exabytes
10246
ZB
Zettabytes
10247
YB
Yottabytes
10248
parse_presto_data_size(string) → decimal(38)
Convert formatted values with a unit to a number. The value can be a decimal.
SELECT parse_presto_data_size('1B'); -- 1
SELECT parse_presto_data_size('1kB'); -- 1024
SELECT parse_presto_data_size('1MB'); -- 1048576
SELECT parse_presto_data_size('2.3MB'); -- 2411724
typeof(expr) → varchar
Returns the data type name of an expression.
SELECT typeof(123);-- integer
SELECT typeof('cat');-- varchar(3)
SELECT typeof(cos(2)+1.5);-- double
