Updated on 2024-05-29 GMT+08:00
DELETE
Syntax
DELETE FROM table_name [ WHERE condition ]
This statement is used to delete data from a table.
In the current version, you can run the delete command to delete the data of an entire table or a specified partition in a partition table.
For a transaction table (the attribute transactional is set to true ), if the where condition is specified, the rows that match the condition are deleted.
Example
Non-transaction table scenario:
  • Clear the table data.
    --Create a table and insert data into the table.
     create table tb_del as select * from (values(1,'suse'),(2,'centos'),(3,'euler')) as t (id,os);
    select * from tb_del;
     id |   os
      1 | suse
      2 | centos
      3 | euler
    (3 rows)
    --A single data record cannot be deleted using the WHERE clause.
    delete from tb_del where id =1;
    Query 20201116_081955_00027_iyct5@default@HetuEngine failed: This connector only supports delete where one or more partitions are deleted entirely for Non-Transactional tables
    --Clear the table data.
    delete from tb_del;
     id | os
    (0 rows)
  • Delete the partition(date='2020-07-17', country='US') partition from the hive.web.page_views partition table.
    delete from hive.web.page_views where ds=date '2020-07-17' and country='US';
Transaction table scenario: deleting a specified record
-- Create a transaction table.
create table tb_trans(a int,b string) with (transactional=true);
CREATE TABLE
-- Insert data.
insert into tb_trans values(1,'a'),(2,'b'),(3,'c');
INSERT: 3 rows
-- Delete data.
delete from tb_trans where a=1;
DELETE: 1 row
