Why Does Automatic Node Pool Scaling Fail in a CCE Cluster?
Symptom
When multiple nodes in a cluster become unavailable, the auto scaling function of the CCE Cluster Autoscaler add-on may stop working, preventing new containers from being scheduled.
In Kubernetes events, a ClusterUnhealthy event appears in the cluster-autoscaler-status ConfigMap.
Possible Cause
CCE Cluster Autoscaler stops scaling when the number of unavailable nodes exceeds the value of ok-total-unready-count (default: 3) and the percentage of unavailable nodes exceeds the value of max-total-unready-percentage (default: 45).
| Parameter | Description | Default Value |
| max-total-unready-percentage | Maximum percentage of unready nodes allowed in a cluster. If exceeded, CCE Cluster Autoscaler stops scaling. | 45 |
| ok-total-unready-count | Maximum number of unready nodes allowed in a cluster, regardless of percentage. | 3 |
- Example 1: If four nodes are unavailable out of six total, the percentage of unavailable nodes is 66.67%.
If the number of unavailable nodes is greater than the value of ok-total-unready-count (3) and their percentage exceeds the value of max-total-unready-percentage (45%), CCE Cluster Autoscaler will stop scaling.
- Example 2: If three nodes are unavailable out of five total, the percentage of unavailable nodes is 60%.
If the number of unavailable nodes is less than or equal to the value of ok-total-unready-count (3), their percentage exceeds the value of max-total-unready-percentage (45%), and the scale-out conditions are met, CCE Cluster Autoscaler will add two more nodes, increasing the total to seven.
Fault Locating
- Log in to the CCE console.
- Check the number of available nodes and the total number of nodes.
- Click the cluster name to access the cluster console. In the navigation pane, choose Add-ons. In the right pane, locate CCE Cluster Autoscaler.
- Click View Details, switch to the Pods tab, select a pod, and choose More > View YAML.
- Check the configuration of spec.containers.command. If ok-total-unready-count and max-total-unready-percentage are not configured, their default values are used.
