Help Center/
Cloud Container Engine/
FAQs/
Node/
Node Running/
What Can I Do If a GPU Card Is Unavailable on a GPU Node?
Updated on 2025-06-18 GMT+08:00
Symptom
A GPU card on a GPU node is unavailable. The possible causes include:
- The CCE AI Suite (NVIDIA GPU) add-on is not ready or malfunctioning.
- The node driver is not ready.
- The GPU card is abnormal.
Figure 1 An unavailable GPU card
Solution
Check whether the driver is faulty. Then, check the device-plugin component of the CCE AI Suite (NVIDIA GPU) add-on. Finally, check the GPU card.
