Why Does a PV Fail to Be Mounted to a Pod After the PV Is Re-bound to a Released EVS Disk?
Symptom
When an EVS volume is mounted to a pod, the error message "wrong fs type, bad option, bad superblock on /dev/sda, missing codepage or helper program, or other error" is displayed.
Possible Cause
The file system type of the underlying EVS disk must match that of the PV when it is first bound to a pod. If a released EVS disk is re-bound to a PV, the PV's file system type must remain consistent with the original PV. If the file system types do not match, CCE detects inconsistencies between the PV file system type and the disk file system type, resulting in a mounting failure.
Solution
Create a new EVS disk for future use.
