What Should I Do If a Node Pool Is Abnormal?
Troubleshooting
Locate the fault based on the status of the abnormal node pool, as shown in Table 1.
| Abnormal Node Pool Status | Description | Solution |
| Error | The node pool cannot be deleted. | Delete the node pool again. If the node pool still cannot be deleted, submit a service ticket and try to delete it again. |
| QuotaInsufficient | The node pool cannot be scaled out due to insufficient quota. | Submit a service ticket to increase the quota. |
| SoldOut | The underlying resources are insufficient. | Update the node pool configuration and select other available resources. |
| ConfigurationInvalid | The ECS group does not exist (ServerGroupNotExists). The ECS group bound to the node pool does not exist. The possible cause is that the ECS group is manually deleted. |
| Invalid private image configuration (InvalidPrivateImage): The private image specified for the node pool requires a minimum disk size (MinDisk) that exceeds the system disk capacity configured for the node pool. As a result, scale-out fails. | Log in to the CCE console. In the navigation pane, choose Nodes, click the Node Pools tab, locate the row containing the target node pool, and click Update. In the Storage Settings area, change the system disk capacity. | |
| InstanceAboveServerGroup | The number of ECSs in the ECS group exceeds the maximum allowed. |
| InvalidCapacityReservation | A capacity reservation error occurs. | Update the node pool and select other capacity reservation specifications. |
| MaxNodeCountReached | The number of expected nodes in the current node pool or scaling group has reached the maximum allowed limit. |
| HasAbnormalNode | Some nodes in a node pool or scaling group are abnormal. |
| Insufficient permissions | Insufficient permissions for the cloud server agency. Node pool scale-out is blocked. |
