Help Center/ Cloud Container Engine/ FAQs/ Chart and Add-on/ How Do I Configure Add-on Resource Quotas Based on Cluster Scale?
Updated on 2026-09-29 GMT+08:00
After changing the cluster scale, adjust the add-on resource quotas based on the cluster scale to ensure that the add-on pods can run properly. For example, if you expand the cluster scale from 50 worker nodes to 200 worker nodes or more, increase the CPU and memory quotas of the add-on pods to avoid exceptions such as OOM caused by too many nodes required for scheduling the add-on pods.
Configuring Resource Quotas for CoreDNS
Queries per Second (QPS) of the CoreDNS add-on is positively correlated with the CPU consumption. If the number of nodes or containers in the cluster grows, the CoreDNS pod will bear heavier workloads. Adjust the number of add-on pods and their CPU and memory quotas based on the cluster scale.
Table 1 Recommended values for CoreDNS
Nodes
Recommended Configuration (QPS)
Pods
CPU Request (m)
CPU Limit (m)
Memory Request (MiB)
Memory Limit (MiB)
50
2500
2
500
500
512
512
200
5000
2
1000
1000
1024
1024
1000
10000
2
2000
2000
2048
2048
2000
20000
4
2000
2000
2048
2048
Configuring Resource Quotas for CCE Container Storage (Everest)
After the cluster scale is adjusted, the everest specifications need to be modified based on the cluster scale and the number of PVCs. The requested CPU and memory can be adjusted based on the number of nodes and PVCs. For details, see Table 2.
In non-typical scenarios, the formulas for estimating the limit values are as follows:
  • everest-csi-controller
    • CPU limit: 250m for 200 or fewer nodes, 350m for 1000 nodes, and 500m for 2000 nodes
    • Memory limit = (200 MiB + Number of nodes × 1 MiB + Number of PVCs × 0.2 MiB) × 1.2
  • everest-csi-driver
    • CPU limit: 300m for 200 or fewer nodes, 500m for 1000 nodes, and 800m for 2000 nodes
    • Memory limit: 300 MiB for 200 or fewer nodes, 600 MiB for 1000 nodes, and 900 MiB for 2000 nodes
Table 2 Recommended configuration limits in typical scenarios
Configuration Scenario
everest-csi-driver
Nodes
PVs/PVCs
Add-on Pods
CPU Cores (Limit = Request)
Memory (Limit = Request)
50
1000
2
250m
600 MiB
300m
300 MiB
200
1000
2
250m
1 GiB
300m
300 MiB
1000
1000
2
350m
2 GiB
500m
600 MiB
1000
5000
2
450m
3 GiB
500m
600 MiB
2000
5000
2
550m
4 GiB
800m
900 MiB
2000
10000
2
650m
5 GiB
800m
900 MiB
Configuring Resource Quotas for autoscaler
autoscaler automatically adjusts the number of nodes in a cluster based on workloads. Adjust the number of add-on pods and their CPU and memory quotas based on the cluster scale.
Table 3 Recommended values for autoscaler
Node
Pod
CPU Request (m)
CPU Limit (m)
Memory Limit (MiB)
50
2
1000
1000
1000
1000
200
2
4000
4000
2000
2000
1000
2
8000
8000
8000
8000
2000
2
8000
8000
8000
8000
Configuring Resource Quotas for volcano
After the cluster scale is increased, the resource quotas required by volcano need to be modified based on the cluster scale.
  • If the number of nodes is no more than 100, retain the default configuration. The requested vCPUs are 500m, and the limit is 2,000m. The requested memory is 500 MiB, and the limit is 2,500 MiB.
  • If the number of nodes is greater than 100 and no more than 1,000, increase the requested vCPUs by 500m and the requested memory by 1,000 MiB each time 100 nodes (10,000 pods) are added. Set the vCPU limit to 1,500m higher than the requested vCPUs, and the memory limit to 6,000 MiB higher than the requested memory.
  • If the number of nodes is greater than 1,000, see the recommended calculation formula for details about the requested value. It is recommended that the memory limit be 10,000 MiB higher than the requested value.
    Formulas for calculating the requests:
    • CPU request: Calculate the number of nodes multiplied by the number of pods, perform interpolation search using the product of the number of nodes in the cluster multiplied by the number of pods in Table 4, and round up the request and limit to the nearest specifications.
      For example, for 2,000 nodes and 20,000 pods, the requested vCPUs are 40 million (Number of target nodes × Number of target pods = 40 million), which is close to the specification of 700/70,000 (Number of cluster nodes × Number of pods = 49 million). According to the table below, set the requested vCPUs to 4,000m and the limit to 5,500m.
    • Requested memory: It is recommended that 2.4 GiB memory be allocated to every 1,000 nodes and 1.4 GiB memory be allocated to every 10,000 pods. The requested memory is the sum of these two values. (The obtained value may be different from the recommended value in Table 4. You can use either of them.)
      Requested memory = Number of target nodes/1000 × 2.4 GiB + Number of target pods/10,000 × 1.4 GiB
      For example, for 2,000 nodes and 20,000 pods, the requested memory is 7.6 GiB (2 × 2.4 GiB + 2 × 1.4 GiB).
Table 4 Recommended requested resources and resource limits for volcano-controller and volcano-scheduler
Nodes/Pods in a Cluster
CPU Request (m)
CPU Limit (m)
Memory Limit (MiB)
50/5000
500
2000
500
2500
100/1,0000
1000
2500
1500
3500
200/20000
1500
3000
2500
8500
300/30000
2000
3500
3500
9500
400/40,000
2500
4000
4500
10500
500/50000
3000
4500
5500
11500
600/60000
3500
5000
6500
12500
700/70,000
4000
5500
7500
13500
800/8w
4500
6000
8500
14500
900/9w
5000
6500
9500
15500
1000/10w
5500
7000
10500
16500
1100/11w
6000
7500
18500
28500
1200/12w
6500
8000
20000
30000
Configuring Resource Quotas for Other Add-ons
Resource quotas of other add-ons may also be insufficient due to cluster scale expansion. If, for example, the CPU or memory usage of the add-on pods increases and even OOM occurs, modify the resource quotas as required.
For example, the resources occupied by the Cloud Native Cluster Monitoring add-on are related to the number of pods in the cluster. If the cluster scale is expanded, the number of pods may also grow. In this case, increase the resource quotas of the add-on pods.
