How Do I Prevent a Non-GPU or Non-NPU Workload from Being Scheduled to a GPU or NPU Node?
Symptom
If there are GPU/NPU nodes and other types of nodes running in your cluster, the non-GPU/NPU workloads may be scheduled to the GPU/NPU nodes. In this case, the GPU/NPU resources cannot be used properly.
Possible Cause
The non-GPU/non-NPU workloads use the vCPUs and memory provided by the GPU/NPU nodes. The scheduler may schedule the non-GPU/NPU workloads to these nodes, even if the workloads do not claim to use the GPU/NPU nodes. This may result in the idle GPU/NPU resources.
Solution
Add taints to the GPU/NPU nodes and configure tolerations to prevent non-GPU/non-NPU workloads from being scheduled to these nodes.
- For the GPU/NPU workloads, add tolerations so that they can be scheduled to the GPU/NPU nodes.
- For the non-GPU/NPU workload, if tolerations are not configured, they cannot be scheduled to the GPU/NPU nodes.
The procedure is as follows:
- In the navigation pane, choose Nodes. Click the Nodes tab, select a GPU/NPU node, and click Labels and Taints above the list.
- Click Add Operation under Batch Operation and add a taint to the node.
Select Taint. Enter the key and value and select the taint effect. The following example shows how to add the accelerator=true:NoSchedule taint to the GPU/NPU nodes.
Figure 1 Adding a taint
- When creating a GPU/NPU workload, manually add a toleration in the Advanced Settings area. Figure 2 Adding a toleration
- When creating a non-GPU/NPU workload, do not add any tolerations. This workload will not be scheduled to the GPU/NPU nodes.
