Help Center/
Cloud Container Engine/
FAQs/
Cluster/
Cluster Running/
How Do I Change the Name of a CCE Cluster?
Updated on 2025-04-25 GMT+08:00
After a cluster is created, you can change its name.
- Log in to the CCE console and click the cluster name to access the cluster Overview page.
- In the Basic Info area, click
next to the cluster name.
Figure 1 Changing the cluster name
- On the page displayed, enter a new name, which must contain 4 to 128 characters, start with a lowercase letter, and not end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
Click Save. Once the changes are saved, the cluster name will update automatically to reflect the new name.
- The new name cannot be the same as its original name or the name of another cluster.
- After the name is changed, the CTS, RMS, and EPS records will be renamed accordingly.
