How Do I Configure the IPv6 Service CIDR Block When Creating a CCE Turbo Cluster?
Context
To create an IPv4/IPv6 dual-stack CCE Turbo cluster, you need to set an IPv6 Service CIDR block. The default CIDR block is fc00::/112, which contains 65,536 IPv6 addresses. If you need to customize a Service CIDR block, you can refer to this section.
IPv6
IPv6 address
An IPv6 address is a 128-bit binary string, four times the length of an IPv4 address. Therefore, the decimal notation used for IPv4 addresses is no longer suitable. IPv6 uses hexadecimal representation, converting the 128-bit binary value into 32 hexadecimal digits. Every four hexadecimal digits (case-insensitive) form one group, with each group separated by a colon (:), resulting in a total of eight groups.
An IPv6 address can be omitted in the following ways:
- Omission of leading 0s: 0s can be omitted if the colon group starts with 0s. The following IPv6 addresses are the same.
- ff01:0d28:03ee:0000:0000:0000:0000:0c23
- ff01:d28:3ee:0000:0000:0000:0000:c23
- ff01:d28:3ee:0:0:0:0:c23
- Omission of all-0s hextets: You can use a double colon (::) to represent a single contiguous string of all-0s segments. A double colon (::) can be used only once.
IPv6 address segment
An IPv6 address segment is usually expressed in CIDR format. It is represented by a slash (/) followed by a number, that is, IPv6 address/Prefix length. The prefix length works similarly to the subnet mask in IPv4. It specifies how many bits of the IP address represent the network portion. Based on this prefix, an IPv6 address is divided into the network address and the host address. The prefix specifies the number of bits occupied by the network part, and the remaining bits are the host part.
For example, fc00:d28::/32 indicates an IPv6 address segment with a 32-bit prefix. The first 32 bits (fc00:d28 in binary mode) are the network part and the last 96 bits are available host part.
Constraints on IPv6 Service CIDR Blocks
When setting the cluster service CIDR block, note the following constraints:
- The IPv6 Service CIDR block must belong to the fc00::/8 CIDR block.
The address is a unique local address (ULA). The ULA has a fixed prefix fc00::/7, including fc00::/8 and fd00::/8. The two ranges are similar to the dedicated IPv4 network addresses 10.0.0.0/8, 172.16.0.0/12, and 192.168.0.0/16. They are equivalent to private CIDR blocks and can be used only on the local network.
- The prefix ranges from 112 to 120. You can adjust the number of addresses by adjusting the prefix value. The maximum number of addresses is 65,536.
Example of an IPv6 Service CIDR Block
According to the constraints, this section provides an example of setting an IPv6 CIDR block that contains 8192 IP addresses for your reference.
- Set the prefix length based on the number of addresses. The prefix length ranges from 112 to 120.
In this example, 8,192 IP addresses are required, which are represented by 13-bit binary strings. An IPv6 address has a total length of 128-bit binary strings. As a result, the prefix length of the IPv6 CIDR block is 115 (128-13). This means that the first 115 bits are used to distinguish the CIDR block, while the last 13 bits indicate 8,192 host IP addresses.
The following table shows how many IP addresses are there in an IPv6 CIDR block with the prefix ranging from 112 to 120.
Prefix Length
Number of IP Addresses
112
65,536
113
32,768
114
16,384
115
8,192
116
4,096
117
2,048
118
1,024
119
512
120
256
- Set the IPv6 network address, which must belong to the fc00::/8 CIDR block.
In this example, the prefix length is 115. Because the network address must belong to the fc00::/8 CIDR block, the first 8-bit binary digits are fixed. The network address that can be modified ranges from the ninth bit to the 115th bit. The 116th bit to the 128th bit are the host part.
If the IPv6 CIDR block is written in binary format, the following conditions must be met:
- It must belong to fc00::/8, and the first eight bits in the binary string cannot be modified. Otherwise, the IPv6 CIDR block does not belong to fc00::/8. The CIDR block is fixed at 1111 1110, corresponding to fc in hexadecimal format.
- The prefix length must be 115, and it must contain 8,192 IP addresses. The last 13 bits in the binary string are used to indicate the host IP address and are always 0.
The following shows an example and the information in red cannot be modified:
Binary: 1111 1100 **** **** ... ***0 0000 0000 0000/115 | | | | | | | | Hexadecimal: f c x x ... y 0 0 0/115x is a hexadecimal string. The last digit of the 4-bit binary string corresponding to y is always 0. This means that the hexadecimal string y can be 0, 2, 4, 6, 8, a, c, or e.
