Where Can I Get the Listening Ports of CCE Worker Nodes?
| Destination Port | Protocol | Description |
| 10248 | TCP | Health check port for kubelet |
| 10250 | TCP | Service port of kubelet to provide monitoring information about workloads on nodes and access channels for containers |
| 10255 | TCP | Read-only port of kubelet to provide monitoring information about workloads on the node |
| Dynamic port (related to the range of the host machine, for example, the kernel parameter net.ipv4.ip_local_port_range) | TCP | Random port listened by kubelet, which is used to communicate with CRI Shim to obtain the EXEC URL. |
| 10249 | TCP | kube-proxy metric port to provide kube-proxy monitoring information |
| 10256 | TCP | Health check port for kube-proxy |
| Dynamic port (32768-65535) | TCP | WebSocket listening port for functions such as docker exec |
| Dynamic port (32768-65535) | TCP | WebSocket listening port for functions such as containerd exec |
| 28001 | TCP | Local listening port of ICAgent to receive syslog logs of the node |
| 28002 | TCP | Health check port for ICAgent |
| 20101 | TCP | Health check port of yangtse-agent/canal-agent (involved when the container tunnel network model is used) |
| 20104 | TCP | Metric port of yangtse-agent/canal-agent to provide component monitoring information (involved when the container tunnel network model is used) |
| 3125 | TCP | Health check listening port of everest-csi-driver |
| 3126 | TCP | everest-csi-driver pprof port |
| 19900 | TCP | Server port for the health check of node-problem-detector |
| 19901 | TCP | Port for connecting node-problem-detector to Prometheus to collect monitoring data |
| 4789 | UDP | OVS listening port, which is used to transmit VXLAN packets in container networking (involved when the container tunnel network model is used) |
| 4789 | UDPv6 | OVS listening port, which is used to transmit VXLAN packets in container networking (involved when the container tunnel network model is used) |
| Dynamic port (30000-32767) | TCP | Listening port of kube-proxy for Layer 4 load balancing. Kubernetes allocates a random port to NodePort and LoadBalancer Services. The default port number ranges from 30000 to 32767. |
| Dynamic port (30000-32767) | UDP | Listening port of kube-proxy for Layer 4 load balancing. Kubernetes allocates a random port to NodePort and LoadBalancer Services. The default port number ranges from 30000 to 32767. |
| 123 | UDP | Listening port of ntpd used for time synchronization |
| 20202 | TCP | Listening port of PodLB for Layer 7 load balancing, which forwards container image pull requests. |
