Help Center/ Cloud Container Engine/ FAQs/ Workload/ Others/ Why Is the Mount Point of a Docker Container in the Kunpeng Cluster Uninstalled?
Updated on 2026-06-26 GMT+08:00
Symptom
The mount point of a Docker container in the Kunpeng cluster is uninstalled.
Possible Cause
If the Kunpeng cluster node runs EulerOS 2.8 and the MountFlags=shared field is configured in the Docker service file, the container mount point will be uninstalled due to the systemd feature.
Solution
Modify the Dockerfile, delete the MountFlags=shared field, and restart Docker.
  1. Log in to the node.
  2. Run the following command to delete the MountFlags=shared field from the configuration file and save the file:
    vi /usr/lib/systemd/system/docker.service
  3. Run the following command to restart Docker:
    systemctl restart docker
