Help Center/ Cloud Container Engine/ FAQs/ Networking/ Network Exception Troubleshooting/ Why Can't an Ingress Be Accessed from Outside the Cluster?
Updated on 2026-06-26 GMT+08:00
Ingresses forward requests based on Layer 7 HTTP and HTTPS protocols. As an entry of cluster traffic, ingresses use domain names and paths to achieve finer granularities. After an ingress is added to a cluster, the cluster may fail to be accessed. This section describes how to locate the fault when an ingress fails to be added or cannot be accessed. Before rectifying ingress issues, read the following precautions and perform a self-check:
  • If the host address is specified in the ingress, the IP address cannot be used for access.
  • Check the node security group of the cluster and ensure that the service ports in the range of 30000 to 32767 are accessible to all network segments for inbound traffic.
Fault Locating
This section provides an overview of troubleshooting ingress external access exceptions, as shown in Figure 1.
Figure 1 Fault locating overview
  1. Checking Whether the Exception Is Caused by the Ingress
    Check whether the problem is caused by the ingress. Ensure that the external domain name resolution is normal, the security group rules are correct, and the service and workload corresponding to the ingress are working properly.
  2. Checking the Ingress Status
    When the service and workload are normal, ensure that the load balancer on which the ingress depends is normal. If the ingress is of the Nginx type, ensure that the NGINX Ingress Controller add-on runs properly.
  3. Checking Whether the Ingress Is Configured Correctly
    If the preceding check results are normal, the ingress configuration may be incorrect.
    • Check whether the parameters for interconnecting with the load balancer are correct.
    • Check whether the Service configuration is correct.
    • Check whether the forwarding configuration is correct.
  4. Checking Certificate
    If HTTPS access is enabled on the ingress, you also need to check whether the fault is caused by incorrect certificate configuration. You can use the same load balancer to create an HTTP ingress. If the access is normal, the HTTPS certificate may be faulty.
  5. If the fault persists, capture packets for analysis or submit a service ticket for help.
Check whether the access exception is caused by the ingress. If a domain name resolution exception, security group rule error, service exception, or workload exception occurs, the ingress access may fail.
The following check sequence complies with the rules from outside to inside:
  1. Check whether the domain name resolution or security group rules are normal.
    1. Run the following command to check whether record sets of the domain name take effect on the authoritative DNS server:
      nslookup -qt= Type Domain name Authoritative DNS address
    2. Check the security group rules of the cluster nodes and ensure that the service ports in the 30000–32767 range are accessible to all network segments for inbound traffic. For details about how to harden the security group, see How Do I Modify Cluster Security Group Rules?
  2. Check whether the Service can access services in the container.
    You can create a pod in the cluster and use the cluster IP address to access the Service. If the Service type is NodePort, you can also use EIP:Port to access the service over the Internet.
    1. Use kubectl to connect to the cluster and query the Service in the cluster.
      # kubectl get svc
      NAME         TYPE        CLUSTER-IP       EXTERNAL-IP   PORT(S)        AGE
      kubernetes   ClusterIP   10.247.0.1       <none>        443/TCP        34m
      nginx        ClusterIP   10.247.138.227   <none>        80/TCP         30m
    2. Create a pod and log in to the container.
      kubectl run -i --tty --image nginx:alpine test --rm /bin/sh
    3. Run the curl command to access ClusterIP address:Port of the Service to check whether the Service in the cluster is accessible.
      curl 10.247.138.227:80
      If the Service can be accessed, the backend workload status is normal. It can be preliminarily determined that the exception is caused by the ingress. For details, see Checking the Ingress Status.
      If the Service access is abnormal, check the workload status to determine the cause.
  3. Check whether the workload status is normal.
    If the workload is normal but the Service cannot be accessed, the exception may be caused by the Service. Check the Service configuration. For example, check whether the container port is correctly configured to an open service port of the container.
    If the workload is normal but the access result is not as expected, check the service code running in the container.
CCE supports two types of ingresses. The NGINX Ingress Controller is provided by the open-source community. It must be installed as an add-on in the cluster and maintained by the user. The LoadBalancer ingress controller runs on the master node and is maintained by a dedicated Huawei Cloud team.
  1. If you use an Nginx ingress, you need to install the NGINX Ingress Controller add-on in the cluster. If you use a LoadBalancer ingress, skip this step.
    Go to Add-ons and check whether the NGINX Ingress Controller add-on runs properly. Ensure that there are enough node resources in the cluster. If not, the add-on pods cannot be scheduled to nodes.
  2. Go to the ELB console to check the ELB status.
    • LoadBalancer ingress
      The access port can be customized. Check whether the listener and backend server group created on the ELB are not deleted or modified.
      When creating a LoadBalancer ingress, you can enable automatic load balancer creation on the console. Do not modify the automatically created load balancer to prevent ingress exceptions caused by the load balancer.
    • Nginx ingress
      The access ports are fixed to 80 and 443. Custom ports are not supported. Installing the NGINX Ingress Controller add-on occupies both ports 80 and 443. Do not delete them. Otherwise, you need to reinstall the add-on.
    You can also determine whether the fault is caused by the load balancer based on the error code. If the following error code is displayed, there is a high probability that the fault is caused by the load balancer. In this case, you need to pay special attention to the load balancer.
If the preceding check items are normal, check whether the issue is caused by parameter settings. When using kubectl to create an ingress, a large number of parameters need to be set, which is prone to errors. You are advised to use the console to create ingresses and set parameters as required to automatically filter out load balancers and Services that do not meet requirements. This effectively prevents incorrect formats or missing required parameters.
Check the ingress configuration according to the following steps:
    Load balancers are defined by parameters in the annotations field. Kubernetes does not verify the parameters in the annotations field when creating resources. If key parameters are incorrect or missing, an ingress can be created but cannot be accessed.
    The following problems frequently occur:
    • The interconnected ELB load balancer is not in the same VPC as the cluster.
    • Key fields kubernetes.io/elb.id, kubernetes.io/elb.ip, kubernetes.io/ingress.class, and kubernetes.io/elb.port in annotations are missing when a LoadBalancer ingress is associated with an existing ELB load balancer.
    • When you add an Nginx ingress, the NGINX Ingress Controller add-on is not installed. As a result, the ELB connection is unavailable.
    • When you add an Nginx ingress, the kubernetes.io/elb.port field does not support custom ports. If HTTP is used, the value is fixed to 80. If HTTPS is used, the value is fixed to 443.
  • Check whether Service is configured correctly.
    • Check whether the Service type connected to the ingress is correct. For details about the Service types supported by the ingress, see the following table.
      Table 1 Services supported by LoadBalancer ingresses
      Cluster Type
      ELB Type
      ClusterIP
      NodePort
      CCE standard cluster
      Shared load balancer
      Not supported
      Supported
      Dedicated load balancer
      Not supported
      Supported
      CCE Turbo cluster
      Not supported
      Supported
      Supported
      Supported
      Table 2 Services supported by Nginx ingress
      Cluster Type
      ELB Type
      ClusterIP
      NodePort
      Supported
      Supported
      Supported
      Supported
      CCE Turbo cluster
      Supported
      Supported
      Supported
      Supported
    • Check whether the access port number of the Service is correct. The access port number (port field) of the Service must be different from the container port number (targetPort field).
    • The forwarding URL added must exist in the backend application. Otherwise, the forwarding fails.
      For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure that your Nginx application contains the same URL, that is, /usr/share/nginx/html/test, otherwise, 404 is returned.
      When using the Nginx Ingress Controller, you can add the rewrite comment to the annotations field for redirection to rewrite the path that does not exist in the Service to avoid the error that the access path does not exist. For details, see Rewrite.
    • If the domain name (host) is specified when an ingress is created, the ingress cannot be accessed using an IP address.
The ingress secret certificate type of CCE is IngressTLS or kubernetes.io/tls. If the certificate type is incorrect, the ingress cannot create a listener on the load balancer. As a result, the ingress access becomes abnormal.
  1. Remove HTTPS parameters from YAML and create an HTTP ingress to check whether the ingress can be accessed.
    If the HTTP access is normal, check whether the HTTPS secret certificate is correct.
  2. Check whether the secret type is correct. Check whether the secret type is IngressTLS or kubernetes.io/tls.
    kubectl get secret
    Information similar to the following is displayed:
    NAME                  TYPE                                  DATA   AGE
    ingress               IngressTLS                            2      36m
  3. Create certificates for tests to rectify the certificate fault.
    openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout tls.key -out tls.crt -subj "/CN={YOUR_HOST}/O={YOUR_HOST}"
  4. Use the tls.key and tls.crt certificates for tests to create a secret and check whether the secret can be accessed normally. The following example shows how to create an IngressTLS secret.
    Specifically, the IngressTLS secret is created using kubectl:
    kind: Secret
    apiVersion: v1
    type: IngressTLS
      namespace: default
    data:
      tls.crt: LS0tLS1CRU*****FURS0tLS0t
      tls.key: LS0tLS1CRU*****VZLS0tLS0=
    In the preceding information, tls.crt and tls.key are only examples. Replace them with the actual files. The values of tls.crt and tls.key are the content encrypted using Base64.
