Help Center/ Cloud Container Engine/ FAQs/ Networking/ Network Configuration/ How Do I Obtain the Actual Source IP Address of a Client After a Service Is Added into Istio?
Updated on 2026-09-29 GMT+08:00
Symptom
After Istio is enabled, the source IP address of the client cannot be obtained from access logs.
Solution
This section uses the Nginx application bound to an ELB Service as an example. The procedure is as follows:
  1. Enable the function of obtaining the client IP address on the load balancer.
    Transparent transmission of source IP addresses is enabled for dedicated load balancers by default. You do not need to manually enable this function.
    1. Click in the upper left corner of the management console and select a region and a project.
    2. Choose Service List > Networking > Elastic Load Balance.
    3. On the Elastic Load Balance page, click the name of the load balancer.
    4. Click the Listeners tab, locate the row containing the listener, and click Edit. If modification protection exists, disable the protection on the basic information page of the listener and try again.
    5. Enable Transfer Client IP Address.
      Figure 1 Enabling Transfer Client IP Address
  2. Update the gateway associated with a Service.
    1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Services and Ingresses.
    2. On the displayed page, switch to the istio-system namespace and update the gateway associated with the Service.
    3. Change the level of the Service automatically generated in the istio-system namespace to the node level.
  3. Verify the obtained source IP address.
    1. Use kubectl to access the cluster.
    2. Query the Nginx application logs.
      kubectl logs <pod_name>
      In this example, the source IP address obtained by the Nginx application is as follows:
