Help Center/ Cloud Container Engine/ FAQs/ Node/ Node Running/ What Should I Do If Excessive Docker Audit Logs Affect the Disk I/O?
Updated on 2025-04-25 GMT+08:00
Symptom
There are a large number of Docker audit logs on existing nodes in some clusters. Due to OS kernel defects, it is slightly possible that I/Os are suspended. You can optimize the audit log rules to avoid this problem.
Impact
Affected cluster versions:
  • v1.15.11-r1
  • v.1.17.9-r0
    • You only need to fix this issue for existing nodes, not for newly created nodes.
    • The auditd component needs to be restarted during the upgrade.
Check Method
  1. Log in to the worker node as user root.
  2. Run the following command to check whether the problem exists on the current node:
    auditctl -l | grep "/var/lib/docker -p rwxa -k docker"
    If information similar to the following is displayed, the problem exists and needs to be rectified. If no command output is displayed, the node is not affected.
Solution
  2. Run the following commands:
    sed -i "/\/var\/lib\/docker -k docker/d" /etc/audit/rules.d/docker.rules
    service auditd restart
Verification Method
Run the following command to check whether the fault is rectified:
If no command output is displayed, the problem has been resolved.
