Why Can't the Domain Name of the Tenant Zone Be Resolved After the Subnet DNS Configuration Is Modified?
Symptom
After a DNS server record, for example, 114.114.114.114, is added to the DNS configuration of the user cluster subnet, the domain name of the tenant zone cannot be resolved.
Cause Analysis
CCE configures the subnet DNS information of the user on the node, which is also used by the CoreDNS add-on. As a result, the domain name fails to be resolved by the node container occasionally.
Solution
You are advised to modify the stub domain of the CoreDNS add-on to update the DNS configuration of the user cluster subnet. For details, see Configuring the Stub Domain for CoreDNS.
