Help Center/ Cloud Container Engine/ FAQs/ Networking/ Security Hardening/ How Do I Prevent Cluster Nodes from Being Exposed to Public Networks?
Updated on 2024-11-13 GMT+08:00
Question
How do I prevent cluster nodes from being exposed to public networks?
Solution
- If access to port 22 of a cluster node is not required, you can define a security group rule that disables access to port 22.
- Do not bind an EIP to a cluster node unless necessary.
If remote login to a cluster node is required, you are advised to use Huawei Cloud Bastion Host (CBH) as the transit node to connect to the cluster node.
