Help Center/
Cloud Container Engine/
FAQs/
Workload/
Container Configuration/
What Should I Do If Health Check Probes Occasionally Fail?
Updated on 2026-01-05 GMT+08:00
When the liveness and readiness probes fail to perform the health check, locate the service fault first.
Common causes are as follows:
- The service processing takes a long time. As a result, the response times out.
- The Tomcat connection setup and waiting time are too long (for example, too many connections or threads). As a result, the response times out.
- The performance of the node where the container is located, such as the disk I/O, reaches a bottleneck. As a result, the service processing times out.
