Help Center/Cloud Container Engine/FAQs/Cluster/Cluster Running/Why Does CCE Display Node Disk Usage Inconsistently with Cloud Eye?
Updated on 2024-07-04 GMT+08:00
Symptom
The disk usage of a node on the CCE cluster details page is higher than 80%, but the disk usage displayed on the Cloud Eye console is lower than 40%.
After fault locating on the node, it is found that the usage of a PVC disk reaches 92%. After the disk is cleared, the disk usage on CCE is the same as that on Cloud Eye.
Does CCE display only the highest disk usage?
Answer
In the CCE cluster monitoring information, the disk with the highest disk usage on the node is monitored.
